Author Topic: Measuring XTAL (XI, XO)  (Read 15193 times)
Offline caliper15Topic starter
Re: Measuring XTAL (XI, XO)
« Reply #25 on: April 17, 2013, 08:56:27 am »
Something totally different which could be a problem (thinking of what you said about oscillating for 2 seconds and then stopping): is the reset line of the mmc maybe floating?
The mmc doesn't have a reset or enable pin. I've checked all the power input pins and they have the correct values (3.3V and 1.8V) and have decoupling capacitors. I have a previous board using this same circuit and I can measure 12Mhz from both XI and XO. The only real difference I can think of is the different board layout.
