Author Topic: Comparator question?  (Read 2155 times)
Offline etstudentTopic starter
« on: October 28, 2012, 11:25:55 pm »
If the signal to the input is larger than the signal to the non-inverting input of the comparator, what is the result?
Is it a larger positive or negative output or a small positive or negative output? Any hints will be appreciated? Question is confusing me.
Offline PA4TIM
Re: Comparator question?
« Reply #1 on: October 28, 2012, 11:43:50 pm »
Most comprators have an open collector output.
« Reply #2 on: October 29, 2012, 02:33:05 am »
Got it, thank you. The answer is a small positive output. I found the answer in my book after looking 900 times.
With the inverting input larger than the non-inverting input it can't drive the output negative. Am I correct?
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #3 on: October 29, 2012, 03:51:05 am »
if (non-invert input > inverting input) output = +rail
elseif (non-invert input < inverting input) output = -rail
else output = undefined
confusing?
Offline peter.mitchell
« Reply #4 on: October 30, 2012, 06:48:47 am »
From the wikipedia article on comparators;
When the non-inverting input (V+) is at a higher voltage than the inverting input (V-), the high gain of the op-amp causes the output to saturate at the highest positive voltage it can output. When the non-inverting input (V+) drops below the inverting input (V-), the output saturates at the most negative voltage it can output. The op-amp's output voltage is limited by the supply voltage.
