Hi!
I need some help choosing the right sensor to measure current.
The idea is to be able to measure a single phase from a 3-phase motor with rated current of 75A ( bonusstar if it can handle up to 445A) and the signal from it should be received by a DAQ.
The input card can take care of 20mA (-20 to +20mA) or 10V (-10V to +10V) and has 50Ω impedance on the current mode and 107kΩ on the voltage mode.
The crux of the matter is that the installation should preferably not be invasive as the idea is that you can easily move around the measuring points. I started by looking around a little on current tongs but was limited by the low maximum current on the card. Also looked at solutions where the signal was a voltage such as fluke i200S but where the requirement for 1MΩ as input impedance put a spanner in the works.
Will there be major errors if I use the i200S?
Or is the best alternative a split core current transducer and run a current divider, worst case.
Excuse my bad English..
