Author Topic: Current Mirror on the wall ...  (Read 1350 times)
Offline PerranOak
« on: February 08, 2016, 10:37:57 am »
I had just about got to grips with the simple current mirror.
Then I saw an example with one input but multiple outputs - excellent!
However, this suddenly included another BJT (Q1 on the attached) in the input side WITH NO EXPLANATION AT ALL!
Why do they do this just as I am getting it!
Some light can never be seen!
RJD
Offline EPTech
    • EP Technical Services
Re: Current Mirror on the wall ...
« Reply #1 on: February 08, 2016, 11:10:16 am »
Hi There,
This looks more like an equivalent circuit or a circuit for simulation to me. I suggest you find a better circuit.
http://sub.allaboutcircuits.com/images/03129.png
Kind greetings,
Pascal.
Offline Andy Watson
« Reply #2 on: February 08, 2016, 12:07:40 pm »
One input transistor, three output transistors, the output current will be three times the input current. 1:3
Two input transistors, three output, the current will be mirrored 2:3
Although, in practice, variation in Vbe/temperature will probably lead to very disappointing results - unless you can get transistors on the same die.
Offline PerranOak
« Reply #3 on: February 08, 2016, 01:07:13 pm »
Thanks both.
It was really just to understand the concept.
So the "extra" transistor is just to alter the ratio?
RJD
Online Ian.M
« Reply #4 on: February 08, 2016, 01:37:20 pm »
In real life, as the transistors need to be on the same die to match their Vbe, (both process variations and temperature), the current ratio is controlled by the ratio of their emitter junction areas.
Offline w2aew
    • My YouTube Channel
« Reply #5 on: February 09, 2016, 02:45:24 am »
Thanks both.
Yes. This is often done on an IC because it's generally easy to match and ratio transistor sizes/areas etc. one of the 'arts' in IC design is to recognize the component tolerance are pretty poor, but devices match and ration very well - so you design circuits to take advantage of ratios and scaling rather that absolute values.
FAE for Tektronix
