Ok, so in my spare time, I enjoy making and then selling (usually a custom work) funky weird hair extensions made from tubular crin (craft ribbon) called Cyberlox. Fun things, but they're even more awesome if they light up.
This is what they look like, there are two "falls">
http://sphotos.ak.fbcdn.net/hphotos-ak-ash1/hs549.ash1/32059_392809982922_50188822922_4247985_2001523_n.jpgSome colours are highly UV reactive and glow like crazy things. This is my friend Gem, we were at a goth club >
http://c1.ac-images.myspacecdn.com/images02/82/l_2a26368b40f243d2b24f6c27d4ba651c.jpgSome goth clubs don't have blacklights and we like glowy things, so here we go...
So story starts here...
A programmer friend of mine had purchased some UV LEDs (but this is going to work with all colours really, just need voltage adjustments). So basically he has been trying to create strings of LEDs that are controlled by an AVR micro which is programmed via his Arduino. He has had problems burning onto the PICs, which would be cheaper to use in this case, so we're looking at using AVRs. If we used sequential logic, we would have at least 3 chips going.
What we want to do is create strings of these arranged in the charlieplex configuration so it becomes a light chaser when programmed. The programming allows the LEDs be dimmed. Up to 30 LEDs can be run from one chip, so 5 strands of 6 LEDs in each "fall".
Problem is, we need to keep under budget, so we can make somewhat of a profit (or at least break even) when these are sold on. We want to be able to use the cheapest and lightest form of power available. This has to include batteries and a holder to put the batteries in so the person who purchases it can change the batteries as required. We can get away with using AAA batteries, but only if we use 3V on these LEDs, which isn't so bright. The batteries can get heavy, so we're thinking coin cells. We want these LEDs to operate at 5V. Weight is the key issue, we can't have them too heavy because it's not fair on one's scalp to pull the hair so hard. Cyberlox are very light to wear, so we want to keep it as light as possible.
The budget is $20AUD for the project, because the hair extension customers won't want to pay an extra $50-$100AUD for this sort of thing.
Any suggestions for batteries, battery holders and Arduino advice?
And by the way, I'm only very new to Microcontrollers, we've only just started our lessons at TAFE/college, so think of me as a layman!
Cheers!
L.
PS ~ We wanted to use EL wire in these hair extension bobbies, but the inverter is too big and too heavy, so LEDs were the next option!
