Hello. Newbie here. Have some questions i'm hoping you can help me with.
And feel free to suggest better ways to do this.
I'm helping some retired guys who are building a big outdoor railroad. My current project is figuring out how to sense when a train is in a certain section of track or "block". These are large trains. We expect them to draw about 10 amps and 32 volts. I'm hoping i can sense the first amp as my "trigger."
I want to try and go the route of using a shunt and a comparator ( or 2 or 3). I've come across mentions of a Texas Instruments chip that sounded good, then stumbled across another that sounds better.
I'm looking at the ina250. Biggest plus i'm seeing is that it has a built-in shunt. But i don't understand the datasheet enough to know if it will work for me; things like offset voltage.
https://www.ti.com/product/INA250I've never played with a comparator or op-amp. I'm of the understanding that the output is either high or low, that it can be used as a trigger, in this case i want to connect it to an arduino to trigger signal lights.
The INA303 has more functions, like alerts, but i don't know if i need those. And it doesn't have a built-in shunt.
So, that's where i'm at. Hoping someone that is knowledgeable can check out the data sheet and let me know if it will/will not work.
Thanks for any info you can send my way.
Marty
