thanks for your reply.
The INA300 looks quite nice as over current protection device. First I thought it cannot be used in a bi-directional current flow setup, but reading the data sheet shows this application is possible with two oINA300 which is nice.
To clarify my requirements: I want this current sensing and over current protection board to protect a double h-bridge (See my other post here:
https://www.eevblog.com/forum/projects/double-brushed-motor-controller-feedback-appreciated/).
So, with the INA300, the over current protection part is much easier to implement than on my original design. Thanks for that!
Regarding the LT1999 output signal scaling, I just realized, that digitizing it directly on this board might be the better approach. As the LT1999 and the ADC share the same Vcc/Vref, the output of the ADC is always ratiometric. Ensuring that with a "distributed" setup might be a little harder.
To sum it up:
- I'll ditch the LM339 in favour of the INA300 for the protection part.
- I'll use a ADC to digitize the LT1999's outputs and do the communication between ADC and MCU via a bus
What would be a appropriate ADC for this purpose?
Thanks in advance!
Regards
Kryp
