Hi all, just a quick one. All of the integrated DAC'a I've been working with had separate AGND and DGND connections - no problem whatsoever. Then there is this LTC1450 from Linear I have to use and it appears it has only one GND pin.
I have separate analog and digital ground planes connected only in one point, in the power supply section, and the question is : Should I connect this DAC to analog or digital ground? The datasheet doesn't say a thing about it, and I just don't want to end up with a huuuuge ground loop + second AGND-DGND connection point...
