Author Topic: Current sources vs sinks  (Read 2280 times)
Offline Analog KidTopic starter
« on: January 06, 2025, 10:10:38 pm »
We're taught, from an early age, that this is the proper configuration for a current source:
and that this is the proper setup for a current sink:
But what if instead we use this as a sink?
and this as a source?
Question 1: Will these alternate configurations work?
Question 2: Will they work, but with some deficiency?
I'm really not trying to stir up a hornet's nest here: I'm just trying to wrap my head around this basic electronic concept.
It seems to me that really, either way should work, because if we think of the transistor as a device that passes current through from collector to emitter (conventional current flow direction, not electron flow), similar to a valve with some fluid flowing through it, why should it matter whether we tap the current at the top or at the bottom?
Now there is the matter of base current, which flows out of the emitter of the NPN and therefore adds to that current.
However, IB is so small compared to IE that it's basically "swamped" and can therefore be ignored, right?
This is basically the same as the high-side switch vs. low-side switch thing.
Just to be clear, I am excluding applications like precision current sources here; I'm proposing a typical current source that's just accurate enough.
« Last Edit: January 06, 2025, 10:42:40 pm by Analog Kid »
Online TimFox
Re: Current sources vs sinks
« Reply #1 on: January 06, 2025, 10:24:27 pm »
The distinction between source and sink:
A source supplies current to an external load from its internal power source.
A sink is a load for an external source.
Example: the traditional 7400 TTL output uses an NPN collector as a sink for current sourced by the next gate’s input emitter (from its power supply) to pull the output voltage down sufficiently for logic-low output.  For logic high, the totem-pole pull-up is a source to supply enough current (less than the low-state current) to obtain a voltage sufficiently positive to turn off the next gate’s emitter.
The four circuits you show are all sources, of different current direction, from the indicated power source “V+”.
« Last Edit: January 06, 2025, 10:26:11 pm by TimFox »
The following users thanked this post: pqass
« Reply #2 on: January 06, 2025, 10:40:58 pm »
OK, but that didn't really answer my question, unless the answer was implicit (in which case I missed it):
Will those all work?
Will they all work equally well?
And if they're all sources, what would a current sink look like?
Offline pqass
« Reply #3 on: January 06, 2025, 10:49:12 pm »
Yes the alternates will work (as a switch) BUT a base current must flow to turn on the transistor (WRT its emitter) and keep it on.
The only way to do that with a PNP collector on GND is to produce a voltage below ground out of the base resistor.
And with an NPN collector on V+ is to produce a voltage above V+ into the base resistor.
« Last Edit: January 06, 2025, 11:11:55 pm by pqass »
The following users thanked this post: WillTurner, Analog Kid
Offline PGPG
« Reply #4 on: January 06, 2025, 10:51:34 pm »
Have you heard about emitter follower?
Online TimFox
« Reply #5 on: January 06, 2025, 10:51:38 pm »
Another distinction, specifically for current:  a good current sink exhibits a low impedance to the external current source, while a good current source has a high impedance to the external sink or load.
If you use a collector (PNP or NPN) to drive the load, that is a reasonable current source.
However, an emitter (PNP or NPN) drives the load from a relatively low impedance and is therefore better treated as a voltage source;  it also works as a current sink from an external source.
This assumes that the transistor is in its active region (not saturated).
A saturated transistor (switched hard ON) presents a low impedance at the collector.
Otherwise, calling the circuit a source or sink depends on the configuration and location of power sources, as I discussed above.
Online tggzzz
« Reply #6 on: January 06, 2025, 11:02:24 pm »
That is reasonably well described in a book you have said you possess: TAoE, any edition will do.
An answer much deeper than Tim Fox has already given you will probably require considering semiconductor physics. Sorry about that.
Why don't you look at your copy of TAoE; you will then be in a position to ask a a more pointed question.
The following users thanked this post: Smokey
Offline Benta
« Reply #7 on: January 06, 2025, 11:10:07 pm »
Good definition.
Unfortunately, a lot of people define a "source" as current flow from V+ and "sink" as to V-. Let's call it "polarity thinking".
« Reply #8 on: January 06, 2025, 11:10:16 pm »
I think the answer that @pqass gave is the one that's needed here.
I completely disregarded the biasing requirements for a source/sink circuit.
I believe this pretty much trumps any other discussions here, with maybe the exception of source/sink impedance:
The "alternate" circuits I posted simply won't work without outlandish biasing schemes (V below ground for PNP, V above V+ for NPN).
Online TimFox
« Reply #9 on: January 06, 2025, 11:18:53 pm »
Good definition.
That usage is similar to "source" and "sink" in generalized field theory, for example showing the velocity field for weather or the magnetic field from a bar magnet.
This was covered fully in the classic P M Morse and H Feshbach Methods of Theoretical Physics, McGraw-Hill 1953 (2 vols.)
I kept this book on my shelf at work:  when someone asked me a complicated question, I referred them to that book, and they didn't bother me any more.
https://www.physicsforums.com/threads/has-anyone-ever-finished-reading-morse-feshbach-and-courant-hilbert.1054844/
« Reply #10 on: January 06, 2025, 11:19:50 pm »
Again with the totally unhelpful "I'm not going to answer your question: read the book".
OK, wise guy: I have read what The Art of Electronics by Horowitz & Hill has to say on the subject.
Specifically from pp. 59-62 in my edition.
Yes, they have many good things to say about current sources.
However, they have really nothing to say about the difference betwixt current sources and sinks, which of course is the topic of this thread. All they write is this:
The other examples (using npn transistors) should properly be called current sinks, but the usual practice is to call all of them current sources.
Which of course doesn't really address my questions.
And as I wrote above, the answer given by pqass is a show-stopper that would stop my alternative examples from working without extraordinary base biasing schemes. Which I'm assuming is the real reason that the canonical forms of PNP vs NPN configurations are used.
Online tggzzz
« Reply #11 on: January 06, 2025, 11:47:09 pm »
You didn't bother to mention that you had read (some of) the relevant bits in TAoE.
Biassing transistors is always required, so I'm not sure why you regard that as "extraordinary".
TAoE uses the phrase "current sink" at least 70 times; I lost count. Most of those indicate/discuss biassing.
IMHO the best answer to your original question was given by Tim Fox. You were dismissive of his answers. Your subsequent responses indicate that you had asked the wrong question to get the answers you seem to like.
It is, of course, generally true that answering a question right (i.e correctly) is easier than asking the right question.
« Last Edit: January 06, 2025, 11:50:21 pm by tggzzz »
The following users thanked this post: TimFox
« Reply #12 on: January 07, 2025, 12:01:15 am »
I would regard requiring a PNP base bias voltage of below ground, or an NPN bias voltage of above V+ as "extraordinary" because those wouldn't be possible with a single supply voltage to the circuit.
Online TimFox
« Reply #13 on: January 07, 2025, 12:03:40 am »
Single-supply circuits are now fashionable, but many circuits use split or dual supplies.
There are other ways to bias devices, even with a single supply.
« Reply #14 on: January 07, 2025, 12:08:35 am »
Well, sure: I suppose one could use a voltage divider, f'rinstance. Or even a charge pump.
Offline pqass
« Reply #15 on: January 07, 2025, 12:09:20 am »
NPNs/N-FETs are just overall better than their P versions (due to physics).
They're faster, beefier, have lower on resistance, more common, and therefore cheaper.
So it may be worthwhile to produce a bias voltage above V+ using a charge pump or DC-DC converter.
Some gate driver ICs provide a bias voltage so the same FETs/IGBTs can be used on both high and low side.
Online tggzzz
« Reply #16 on: January 07, 2025, 12:16:56 am »
You attach too much importance to a node being marked as "0V" or "ground".
For example, I have a piece of test equipment where, IIRC, some TTL outputs are high/1 if >-18V, and low/0 if <-19.6V. Others in the same equipment are >+2V and <+0.4V respectively. Need to be very careful when placing a scope probe shield on an IC pin :(
« Last Edit: January 07, 2025, 12:19:21 am by tggzzz »
« Reply #17 on: January 07, 2025, 12:23:06 am »
Well, I'll admit that that's a shortcoming in my understanding of electronics.
I'm learning here ...
« Last Edit: January 07, 2025, 12:24:43 am by Analog Kid »
Online TimFox
« Reply #18 on: January 07, 2025, 12:38:47 am »
A resistor can source or sink current,  depending on what you connect it to.
« Reply #19 on: January 07, 2025, 12:53:19 am »
OK, so would you accept this as an accurate illustration of that distinction?
It depends on whether the resistor is above or below the load, correct?
Offline Benta
« Reply #20 on: January 07, 2025, 01:06:48 am »
(Attachment Link)
No. Your circuit is still supplying current to a load. Whether the current is positive or negative is irrelevant. It's a "source".
« Reply #21 on: January 07, 2025, 01:21:11 am »
(Attachment Link)
OK, so can someone please show me what a sink would look like? Preferably in schematic form? (Crayon on cocktail napkin sketch perfectly acceptable.)
Online SteveThackery
« Reply #22 on: January 07, 2025, 01:42:59 am »
Hey! This is new to me. So you're saying that the load has to be external?  In your post (#2) you give examples of a current source and a current sink, and you say that in both cases the load is external (ie in the next chip along).
Well, this requirement is news to me. But more importantly, it must mean that your assertion that all four of Analog Kid's examples are current sources is wrong, because none of the loads he draws are external.
So if the load is not "external" (whatever that now means), what are the circuits Analog Kid has drawn called? Obviously not current sources or current sinks.
« Last Edit: January 07, 2025, 01:45:28 am by SteveThackery »
« Reply #23 on: January 07, 2025, 01:50:04 am »
What they said.
What exactly does "external" mean?
I think it would be very helpful if someone could post examples showing a current source vs. a sink, and showing what an external load looks like.
« Last Edit: January 07, 2025, 02:16:49 am by Analog Kid »
Offline PGPG
« Reply #24 on: January 07, 2025, 09:41:46 am »
I'm not very good in English - it is my second language.
The terms sink and source I met first time in digital ICs datasheets.
How you explain that these outputs are characterized with their source and sink capability even between connecting to output a LED+R to GND or to VCC has absolutely no difference regarding the sense of supplying the current to load - both connections supply the current to LED and in both cases a power source is on the same PCB as IC and load (LED) is also there.
