Author Topic: How can I convert a 42VAC relay to 24 or 12VDC  (Read 2621 times)
Offline elekorsi
  • Country: si
Re: How can I convert a 42VAC relay to 24 or 12VDC
« Reply #25 on: January 28, 2022, 08:43:55 pm »
I am sure that op has a solenoid (valve coil) and as CaptDon said, 24VDC solenoid will work on 48VAC. In fact many solenoid coils are rated for 48VAC and 24VDC. I am 98% sure that it will also work on 42V
Offline Zero999
  • 0999
« Reply #26 on: January 28, 2022, 09:06:46 pm »
No, there's no guarantee a DC solenoid will work on AC. If you power a solenoid designed for DC, from AC, it will vibrate. It's true an AC solenoid will work on DC, but at a lower voltage. The difference is a solenoid designed to work on AC will have a shading coil, where as one designed for DC alone won't.
