Hello Everyone and salutations from the UK!
I got interested in electronics a few months ago and thought I would have a go at fixing my Roberts SolarDAB (V1) radio which was not powering up properly. When plugged in to mains through and adapter I press the power button (It's a soft start button) the screen flashes up with the battery symbol and the speaker makes a 'pop' before turning off again. On the battery it is a similar story, the screen flashes up with the battery symbol but also illuminates before popping and turning off again although this happens less often, but still quite frequently. Playing with the switch a bit and holding it down will eventually turn it on normally though . I thought that the power switch might be a membrane switch and a piece of dirt might have lodged itself between the contacts but it turned out to be just a normal momentary switch. I have noticed that there are two diodes on the power supply board that are getting quite warm, not sure if that is normal though. I have also checked the power supply voltage, all normal (9.5V) I think in the mean time I might try replacing the switch and see if it was just a faulty one. If I were more confident I would do more probing around with a multimeter or oscilloscope but don't want to fry anything.
Sorry I don't know much about the problem, but if you have any general troubleshooting tips please let me know as well as any ideas on what the problem might be.
Many thanks in advance,
Max
