Author Topic: DAC circuit  (Read 3945 times)
Offline nForceTopic starter
  • Country: ee
DAC circuit
« on: January 24, 2019, 06:38:56 pm »
How do we get "K" in this circuit? Is the calculation correct?
Thanks.
Offline awallin
Re: DAC circuit
« Reply #1 on: January 24, 2019, 06:52:53 pm »
didn't your teacher teach you to use units after each number?  ;D
it would also help if you'd specify the unit you want for "K"
The following users thanked this post: nForce
  • Country: ee
Re: DAC circuit
« Reply #2 on: January 24, 2019, 06:58:35 pm »
I think here we don't have any units. K is just a constant to get from ADC to the motor.
Offline Benta
Re: DAC circuit
« Reply #3 on: January 24, 2019, 07:29:39 pm »
Calculation looks OK. Unit is RPM/bit.
  • Country: ee
Re: DAC circuit
« Reply #4 on: January 24, 2019, 08:04:37 pm »
Ok Benta, if you understand, can you explain how do I get "K" and some comments about derivation?
Offline Wimberleytech
Re: DAC circuit
« Reply #5 on: January 24, 2019, 11:19:48 pm »
Is the second term inverted?
Thanks.
  • Country: ee
Re: DAC circuit
« Reply #6 on: January 25, 2019, 06:04:42 pm »
Can anyone explain to me how do we get "K"?
Re: DAC circuit
« Reply #7 on: January 25, 2019, 06:39:16 pm »
My earlier comment was wrong.
  • Country: ee
Re: DAC circuit
« Reply #8 on: January 25, 2019, 07:16:57 pm »
This is great, but can you explain/comment in words what are we doing here? Some description.  :)
Re: DAC circuit
« Reply #9 on: January 25, 2019, 07:29:30 pm »
K is the small-signal gain from the digital input to the RPM of the motor.
If D steps from 0 to 4095, a delta of 4095, then:
4095 * (3.3/4095) (10/1.65) (1500/10) = 3000.  The output rpm changes from -1500 to +1500...a total output delta of 3000.
For a 1 LSB delta for D, the rpm changes:
1 * (3.3/4095) (10/1.65) (1500/10) = 0.7326 rpm
« Last Edit: January 25, 2019, 07:38:02 pm by Wimberleytech »
  • Country: ee
Re: DAC circuit
« Reply #10 on: January 26, 2019, 12:08:35 pm »
Sorry, but I still don't understand. What do you mean by D? DAC? And what is delta?
So DAC outputs a voltage between 0 and 3.3 V.  And because it's 12-bit DAC the resolution is 3.3/4095?
What about those op amps? And there is +10 V or -10 V, shouldn't be the range then 20 V?
Re: DAC circuit
« Reply #11 on: January 26, 2019, 01:20:25 pm »
D is the digital input.  It has a value between 0 and 4095.  When D=0, the output of the DAC is 0, when D=4095, the output of the DAC is 3.3.
"delta" is a change.  0 to 3.3V is a delta of 3.3V.  1V to 2V is a delta of 1V.
The size of an LSB is 3.3/4095.  The smallest unit it can resolve is 1 LSB.
The opamps do what opamps do.
Yes, -10V to +10V is a delta of 20V
Re: DAC circuit
« Reply #12 on: January 26, 2019, 01:39:38 pm »
Here is the circuit with some example values.
Use your circuit analysis skills and analyze the signal path.
  • Country: ee
Re: DAC circuit
« Reply #13 on: January 26, 2019, 02:30:00 pm »
So V1 = 1.65 V.
And your U1 op amp has a gain of 3. In my case since the resistors are all the same, it has a gain of 2.
So: 1.65 * 2 = 3.3, and because the delta is 3.3 then 3.3/3.3 = 1 which is A = 1.
Right? But why is delta important here?
Thank you for your effort.
Re: DAC circuit
« Reply #14 on: January 26, 2019, 02:38:11 pm »
Delta is important because that is what the original "K" equation was calculating.  Calculating small signal gain.  Dont worry about the -1.65 V voltage source when calculating K.
« Last Edit: January 26, 2019, 02:41:54 pm by Wimberleytech »
  • Country: ee
Re: DAC circuit
« Reply #15 on: January 26, 2019, 04:05:27 pm »
Thanks. So the second term is 10/1.65, because on the output we have 10 V, and at the input, it's 1.65 V. So the gain is 10/1.65, but why 10, because delta is 20V? And why at the motor it's 1500/10, here we are mixing rpm and voltage.
Re: DAC circuit
« Reply #16 on: January 26, 2019, 06:26:33 pm »
The motor speed is 150 rpm/volt.  10 volts yields 1500 rpm.  Ergo..."10V"
  • Country: ee
Re: DAC circuit
« Reply #17 on: January 26, 2019, 07:44:12 pm »
Yes, but delta, as you said why is important: Delta at the motor, is 3000 rpm. Not only 1500 rpm.
Re: DAC circuit
« Reply #18 on: January 26, 2019, 08:00:27 pm »
"K" is the gain of the system: K = Speed/D.  D is the digital input to the DAC.
K is important because this is likely part of a control system where the motor speed is sensed and fed back to the input of the DAC to maintain desired speed.
So, it is a control system (I assume).  In a control system, K is an important parameter associated with, among other things, stability.
If what I just told you makes no sense, then there is no value in me explaining "delta."
  • Country: ee
Re: DAC circuit
« Reply #19 on: January 26, 2019, 08:10:58 pm »
Yes, I understand you.
I am just using the knowledge from known values:
First-term the numerator has delta which is 3.3 V so the same reason for the motor the numerator would have 3000 which is delta. Delta is the difference between min and max.
Re: DAC circuit
« Reply #20 on: January 26, 2019, 09:05:46 pm »
No, the first expression converts bits to volts.  The second expression converts volts to volts.  The third expression converts volts to RPM.
In term of units:
(Volts/bit) (Volts/Volts) (RPM/Volts) = RPM/bit  <--K
If your DAC input changed from 2000 to 2001, a delta of 1 bit, then using the equation, RPM would change by a delta of:
1 * (3.3/4095) * (10/1.65) * (1500/10) = 0.732 RPM
  • Country: ee
Re: DAC circuit
« Reply #21 on: January 26, 2019, 10:14:49 pm »
OK, now I understand in terms of units.
Can you just say why is then 1500 rpm? Or maybe another person can write it.
Let's be consistent:
The first term: delta = 3.3 V - 0 V = 3.3 V
Last term: delta = 1500 rpm - -1500rpm = 3000 rpm.
Re: DAC circuit
« Reply #22 on: January 26, 2019, 10:27:55 pm »
No, you misunderstand "delta"
In the first term 3.3/4095 just the transfer function from the D input to the output of the first amplifier.
As far as 1500rpm.  That is just the designer's choice based on motor used.  No magic.
  • Country: ee
Re: DAC circuit
« Reply #23 on: January 26, 2019, 10:42:39 pm »
Why the first term the range 0-3.3 V is not delta? It seems to me that all the data on the schematic is consistent.
Omg, this is going to take forever.  :(
Re: DAC circuit
« Reply #24 on: January 26, 2019, 10:53:34 pm »
3.3V - 0V is indeed a "delta"
BUT, that is not the first term.  The first term is a transfer function as I said.
How long this takes depends on you.  I understand the circuit and the equations.
You should install LTSPice if you have not already done so.  I will upload the LTSPice file and you can play with it.  Maybe it will help you get a feel for what is going on.
