How did you arrive from wo/Qp=1/(R3*C1)+1/(C2*R4) to Qp=wo^(-1)/(C2*R4+R3*C1) ?
I assume you're referring to the algebra mistake?
Edit:
In the second image in reply #10, the algebra leading from the expression wo/Qp = 1/(R3 C1) + 1/(C2 R4) to the expression
Qp = (wo^-1)/(C2 R4 + R3 C1) would be incorrect if it weren't for the definition of wo as 1/sqrt(R3 R4 C1 C2).
Considering only the apparent algebraic manipulation from the first expression to the second, the algebra appeared to be mistaken. Taking into account the definition of wo, all is well.
Setting R3 and R4 to 10k ohms, and C1 and C2 to .01 uF, we get these numerical values for various expressions. The second expression for Q in the image below comes from reply #2, and appears to be incorrect.
