Option c is to add in a third regulator, probably a small switching converter on a board, pre built, to give you a lower voltage, probably around 8V, so that efficiency is improved considerably. If simply feeding logic from the supplies nothing more filtering wise is needed, otherwise som3e LC filtering of the switching regulator output would be good to reduce the switching noise down to a lower level. Pre made converter modules are cheap, and a simple buck converter will work, as it has adjustable output voltage, making it a drop in part.
