Hello Crew,
This is a general warning to all newbies who have not encountered this problem before.
If you have a system that is earthed, be very careful of using any double insulated items, as they often leak current to their negative output. This applies to two pin plug packs/wall warts, two-pin laptop switching supplies, etc. The problem is that these two pin devices provide a -ve DC output, which is sometimes assumed to be earth potential, but is not (as its insulated from earth) buts it amazing how many people think it is at the same potential as Earth. Below is a photo of a generic double insulated wall wart from a reputable company. There is nothing wrong with it, but when you measure the AC voltage between the -ve DC and EARTH, there is a 120 v AC potential, this is powered from 240v AC.
Although the amount of leakage current is low, it is enough to:
- Give you a tingle if you short the -ve DC and earth
- Send you to hospital if you report the tingle and work in an electrical utility company (they take tingles seriously)
- Blow up the front end of sensitive RF test equipment (that one cost the company $30k USD)
In my work shop, I run earthed power supplies and avoid double insulated plug packs at all costs, particularly DC output ones (AC outputs are normally OK).
If you have to, seriously consider earthing the -ve DC supply rail from the double insulated supply. I have, for example, spliced into a laptop PSU, and manually tied its -ve DC supply to earth. This is particularly important if you are going to connect it (ie: a laptop) via an earthed connection to test equipment (RS-232 serial for example). Not an issue for wireless naturally.
Many of you will already know this, but there may be newbies who have not encountered the problem before. No, I didn't go to hospital, but my colleague yelled out "oh, I think I felt a tingle" next to the safety officer. I remained silent of course!
Apologies if this has been posted before, I could not find it when searching.
Cheers
Luke
