Author Topic: 1 Bit permanent memory  (Read 5431 times)
Offline ChrisGreece52Topic starter
  • Electronics Engineer - Hacker - Nerd
« on: November 19, 2015, 10:07:55 pm »
Hello i wrote again about a project i am working on and need help again ... i need a memory cell to store a 5v signal for a long time i am talking about months here... i dont need it to store the bit without power but as long as it is plugged in i need to be able to store one bit of info.
I did a google search and i found memory modules using not and nand gates but i am not sure if this is permanent or just temporary (for a few minutes)
I need your help with this .
Thank you in advance :)
Online ataradov
    • Personal site
Re: 1 Bit permanent memory
« Reply #1 on: November 19, 2015, 10:21:45 pm »
74HC574 will let you store 8 bits for as long as you like.
You can create an equivalent circuit from  NAND gates, but you won't save any space on the board.
Alex
« Reply #2 on: November 19, 2015, 10:22:42 pm »
Thank you very much now i can get down designing the final circuit
Offline dmills
« Reply #3 on: November 19, 2015, 10:23:24 pm »
A "D" Flipflop, does exactly what you want, or maybe a set/reset latch, which is better depends on your available control signals.
Regards, Dan.
Offline jeroen79
« Reply #4 on: November 19, 2015, 10:30:03 pm »
How about using a very low current fast fuse?
(or something else that will blow quickly at the slightest but of current)
Connect it between GND and a pullup resistor.
When read it will read Low.
To write once you connect it to VCC. Current will flow and the fuse blows.
When you read it again there is no short to GND and the pullup resistor will give a High reading.
Takes just 2 components and will retain it's value even after poweroff.
« Reply #5 on: November 19, 2015, 11:06:18 pm »
i would like to be able to write and read several times... so the d type flip flop is a good solution  ;D
Offline zapta
« Reply #6 on: November 20, 2015, 05:16:30 am »
Offline Richard Crowley
  • KJ7YLK
« Reply #7 on: November 20, 2015, 06:25:18 am »
« Last Edit: November 20, 2015, 06:27:37 am by Richard Crowley »
Online amyk
« Reply #8 on: November 20, 2015, 08:29:58 am »
TI "Little Logic" SOT-23 size D flip-flop
That's so cute. I wonder if anyone has built a computer out of these... TTL and through-hole transistors have been done a few times already.
Offline rgawron
    • blog
« Reply #9 on: November 20, 2015, 10:56:39 am »
You may use a thyristor made from two transistors.
« Last Edit: November 20, 2015, 11:02:05 am by rgawron »
Offline jeroen79
« Reply #10 on: November 20, 2015, 11:08:22 am »
Or use a thyristor made from one thyristor ; )
Offline Zero999
  • 0999
« Reply #11 on: November 20, 2015, 01:06:01 pm »
A bistable can be made from a couple of transistors.
https://en.wikipedia.org/wiki/Multivibrator#Bistable
Offline Kalvin
  • Embedded SW/HW.
« Reply #12 on: November 20, 2015, 01:28:21 pm »
OP may also want to add a Led, and use it as a very cheap logic analyzer. ;)
Offline zapta
« Reply #13 on: November 20, 2015, 01:34:05 pm »
But how do you make the first thyristor?
Offline MatthewEveritt
« Reply #14 on: November 20, 2015, 02:01:39 pm »
Out of a thyristor, obviously. :P
Offline Karel
Offline zapta
« Reply #16 on: November 20, 2015, 02:25:52 pm »
Touche. :)
