I tried search first. all i found was a chip with the same company logo that was a driver of some sort for a SMPS. I believe the company is iweek.cn. I went to their website clicked translate to english when i searched reverted back to Chines. the chip is an LED driver DP9511. Its's a submersible tube with an LED strip. I have repaired several ( replaced burnt out SMD LED) but they only last for a day then I checked the power output way high. I checked the power output of a new one and it was 3v x the number of smd led's. so was wondering if some could get me a data sheet or equivalent data sheet. Something else crossed my mind, well actually 2
1. whatever the count of LEDs they seem to have the same chip. only parts on the pcb are the afore mentioned chip, an electrolytic cap, and a small power resistor. do they use an RC network to select the output voltage?
2. it's possible that the light strips were defective to begin with the higher voltage, like i said the new one was led count times 3v
I think humidity/ condensation may build up and short out the unit......some this happens to others work fine so not sure
I think i found what I was looking for if you want to still look to...great or comment on how the chip functions would like to hear that also
https://www.scribd.com/document/662331058/DP951X-REV1-0-CN
