Hello experts!
I was recapping on a PSU and found i needed high temps in order to melt the solder. Unfortunately i wasn't able to handle the high temps and gauge the soldering time so I may have burned some solder pads.
I have three questions, please help by referring to the attached picture.
Each pair (eg green) refers to one electrolytic capacitor.
i. Capacitor holes linked to A - These are very hard to melt, how can i get a clear through hole for recapping?
ii. Capacitor holes linked to B - These are (comparatively) easier to melt compared to A, again how can i remove solder from the hole for recapping?
I've tried with desoldering braid + 450C on a Ksger T12 soldering tool but it's not really getting the results i want. I've also tried with a solder sucker but the hole closes too fast for the solder sucker to do its work.
should I get a desoldering gun or consider using ChipQuick SMD1 for low melt temps?
iii. Marked C - I've tried to remove this incorrectly and have burnt marks. Is there any way to remove these burnt marks on the PCB?
I've tried cleaning with solder flux. Not sure if this is the correct method.
Please help me EEV gods!
