Author Topic: What is the part marked with a 205?  (Read 588 times)
Offline fixit7Topic starter
« on: June 04, 2019, 02:44:22 am »
What is the yellow part with the 205 on it?
The whole circuit is the detector part of a laser alarm.
The alarm goes off if the laser beam is interrupted.
https://www.dropbox.com/s/esho9ia2oj3mbnz/Laser_Detector_Circuit.png?dl=0
https://www.dropbox.com/s/i5g3qrd5s09mfqa/Laser_Detector_Circuit2.png?dl=0
The photo detector is an awful small surface to have to aim the laser at.
If possible, I would like a photo detector with a larger area.
It works inside, but I have not tested it yet on my patio where the ambient light is much brighter.
Thanks.
« Last Edit: June 04, 2019, 02:48:05 am by fixit7 »
Offline Nerull
Re: What is the part marked with a 205?
« Reply #1 on: June 04, 2019, 02:55:35 am »
A 2 meg trimpot.
The following users thanked this post: fixit7
Offline james_s
« Reply #2 on: June 04, 2019, 04:56:33 am »
If you need a larger area for the detector, use a lens, if you can find a small Fresnel magnifier that should work well. Keep in mind the larger your detection area, the more sensitive it will be to ambient light too.
