Trying to find a simple method to average certain of the sensors...
What I would like to smooth over 100ms:
int wdsReading = analogRead(wdsPin);
delay(10);
Not sure if I should do 10 readings with 10 delays, then add up and divide by 10. Or if there's code do this already done...
The full code right now:
#include <SD.h>
#include <Wire.h>
#include <RTClib.h>
/* Memoire sketch01
#define aref_voltage 3.3 // 3.3V is the ref voltage
#define LOG_INTERVAL 5000 // mills between entries (5s)
#define ECHO_TO_SERIAL 1 // echo data to serial port
#define WAIT_TO_START 0 // Wait for serial input in setup()
// the digital pins that connect to the LEDs
#define redLEDpin 3
#define greenLEDpin 4
// The analog pins that connect to the sensors
#define wdsPin 0 // analog 0
#define tmpPin 1 // analog 1
#define lc1Pin 2 // analog 2
#define lc2Pin 3 // analog 3
#define lc3Pin 4 // analog 4
#define lc4Pin 4 // analog 5
RTC_DS1307 RTC; // define the Real Time Clock object
// for the data logging shield, we use digital pin 10 for the SD cs line
const int chipSelect = 10;
// the logging file
File logfile;
void error(char *str)
Serial.print("error: ");
Serial.println(str);
// red LED indicates error
digitalWrite(redLEDpin, HIGH);
while(1);
void setup(void)
Serial.begin(9600);
Serial.println();
#if WAIT_TO_START
Serial.println("0"); //automatic start, no need to type in anything.
while (!Serial.available());
#endif //WAIT_TO_START
// initialize the SD card
Serial.print("Initializing SD card...");
// make sure that the default chip select pin is set to
// output, even if you don't use it:
pinMode(10, OUTPUT);
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
// don't do anything more:
return;
Serial.println("card initialized.");
// create a new file
char filename[] = "CUBE1.CSV";
for (uint8_t i = 0; i < 100; i++) {
filename[6] = i/10 + '0';
filename[7] = i%10 + '0';
if (! SD.exists(filename)) {
// only open a new file if it doesn't exist
logfile = SD.open(filename, FILE_WRITE);
break; // leave the loop!
if (! logfile) {
error("couldnt create file");
Serial.print("Logging to: ");
Serial.println(filename);
Wire.begin();
if (!RTC.begin()) {
logfile.println("RTC failed");
#if ECHO_TO_SERIAL
Serial.println("RTC failed");
#endif //ECHO_TO_SERIAL
logfile.println("millis,time,temp,speed,sensor1,sensor2,sensor3,sensor");
#if ECHO_TO_SERIAL
Serial.println("millis,time,temp,speed,sensor1,sensor2,sensor3,sensor");
#if ECHO_TO_SERIAL// attempt to write out the header to the file
if (logfile.writeError || !logfile.sync()) {
error("write header");
pinMode(redLEDpin, OUTPUT);
pinMode(greenLEDpin, OUTPUT);
// If you want to set the aref to something other than 5v
//analogReference(EXTERNAL);
void loop(void)
DateTime now;
// delay for the amount of time we want between readings
delay((LOG_INTERVAL -1) - (millis() % LOG_INTERVAL));
digitalWrite(greenLEDpin, HIGH);
// log milliseconds since starting
uint32_t m = millis();
logfile.print(m); // milliseconds since start
logfile.print(", ");
#if ECHO_TO_SERIAL
Serial.print(m); // milliseconds since start
Serial.print(", ");
#endif
// fetch the time
now = RTC.now();
// log time
logfile.print(now.get()); // seconds since 2000
logfile.print(now.year(), DEC);
logfile.print("/");
logfile.print(now.month(), DEC);
logfile.print("/");
logfile.print(now.day(), DEC);
logfile.print(" ");
logfile.print(now.hour(), DEC);
logfile.print(":");
logfile.print(now.minute(), DEC);
logfile.print(":");
logfile.print(now.second(), DEC);
#if ECHO_TO_SERIAL
Serial.print(now.get()); // seconds since 2000
Serial.print(", ");
Serial.print(now.year(), DEC);
Serial.print("/");
Serial.print(now.month(), DEC);
Serial.print("/");
Serial.print(now.day(), DEC);
Serial.print(" ");
Serial.print(now.hour(), DEC);
Serial.print(":");
Serial.print(now.minute(), DEC);
Serial.print(":");
Serial.print(now.second(), DEC);
delay(10);
int tmpReading = analogRead(tmpPin);
delay(10);
// converting that reading to voltage, for 3.3v arduino use 3.3
float voltage = tmpReading * 3.3 / 1024;
float temperatureC = (voltage - 0.5) * 100 ;
int lc1Reading = analogRead(lc1Pin);
delay(5); // Short delay, buffered signal to ground via 10k resistor.
int lc2Reading = analogRead(lc2Pin);
int lc3Reading = analogRead(lc3Pin);
int lc4Reading = analogRead(lc4Pin);
logfile.print(wdsReading);
logfile.println(temperatureC);
logfile.print(lc1Reading);
logfile.print(lc2Reading);
logfile.print(lc3Reading);
logfile.print(lc4Reading);
#if ECHO_TO_SERIAL
Serial.print(", ");
Serial.print(wdsReading);
Serial.print(", ");
Serial.println(temperatureC);
Serial.print(", ");
Serial.print(lc1Reading);
Serial.print(", ");
Serial.print(lc2Reading);
Serial.print(", ");
Serial.print(lc3Reading);
Serial.print(", ");
Serial.print(lc4Reading);
digitalWrite(greenLEDpin, LOW);
