Author Topic: OWERTY  (Read 4536 times)
Offline pranavTopic starter
OWERTY
« on: April 25, 2017, 12:12:30 pm »
« Last Edit: June 27, 2022, 03:36:01 am by pranav »
Offline Molenaar
Re: How to convert DC to AC (for a flyback driver)
« Reply #1 on: April 25, 2017, 12:52:30 pm »
Look up the Mazilli driver, that should do quite well.
Offline Seekonk
« Reply #2 on: April 25, 2017, 03:25:41 pm »
That transformer will produce DC with its internal diode.
Online Zero999
  • 0999
« Reply #3 on: April 25, 2017, 08:56:32 pm »
The simplest way I know of.
http://madlabs.info/flyback.shtml
Offline james_s
« Reply #4 on: April 26, 2017, 12:49:45 am »
These are some others, I've built the mk II one and it works nicely.
http://uzzors2k.4hv.org/index.php?page=flybacktransformerdrivers
« Reply #5 on: April 26, 2017, 12:55:41 pm »
Thanks. I've made a single transistor driver with 2N3055 but the spikes killed by 2N3055
Sent from my Lenovo S850 using Tapatalk
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #6 on: April 26, 2017, 12:59:32 pm »
That's what the circuit is designed to do, by the looks of it.
Seven Transistor Labs, LLC
Online Zero999
  • 0999
« Reply #7 on: April 26, 2017, 01:00:32 pm »
Well the circuit I posted above doesn't use the 2N3055 but the NTE284, which has a much higher voltage rating then the crappy old 2N3055. Failing that, try adding a snubber network.
Offline T3sl4co1l
« Reply #8 on: April 26, 2017, 02:46:34 pm »
This is a bit more responsible of a design,
And yes, for once I'm claiming a 555 is useful for something. ;D
+V can be whatever.  For instance, you can use about +100V and use the primary winding inside the FBT itself (trace the PCB to find these pins).  For the external winding (usually 3-10 turns), 12-24V will be suitable.
An RCD peak clamp snubber, across the transistor, might also be a good idea, to prevent overvoltage.  The RC damper helps, but doesn't limit the peak very much.
I don't have a complete schematic handy, but you would add a diode, resistor and capacitor, connected to the transistor collector/drain just as Q3, D1, C2, RL are connected here: https://www.seventransistorlabs.com/Images/AltiumDiscreteFlybackSch.png
Typical values would be D1 = UF4007, C2 = 10nF and rated at least 2 x +V, RL = 10k 5W or thereabouts (depending on +V, turns, operating frequency, power level, etc.).  You want RL to be small enough that the clamping voltage (the DC voltage on C2) isn't obscene.
