Author Topic: Dave's u-Supply issue  (Read 1736 times)
Offline ikrelTopic starter
« on: January 04, 2013, 02:54:27 am »
I've setup Dave's u-supply from the schematic and I'm having an issue with the voltage follower for the current sense resistor.
I'm reading a constant 22.9v on the output of the follower (24v supply @ 0A) and only get a a few hundred millivolts difference as I adjust the current from the supply from 0-1.5A. if I probe across the resistor i get exactly what you'd expect(0-1.5v).
I've change the op-amp(LM358) and nothing changed. What could be causing this?
