This is my first post on the forums, and I have a question for you concerning a SSR. I am modifying a heat gun to control the temperature precisely with a rex C100 controller and a SSR. The thermocouple is installed inside the nozzle just past the element. Everything is working good except when I tried to install a power diode that I salvaged from the heatgun to reduce the voltage to the element since I don't need it to work at full power.
After I installed the diode, when I turn on the heat gun and the controller, it gets up to the set value but then as soon as it reach the temp and the SSR turns the power off, it won't turn back on. I'd like to know if it's because I have a zero-cross SSR that it doesn't work.
Thanks
