Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
dc-dc boost convetter cascade (series)
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: dc-dc boost convetter cascade (series) (Read 409 times)
tural_h
Newbie
Country:
on:
November 14, 2024, 05:57:02 pm »
hello everyone, i made a cascade dc dc converter using mc34063 but using an external transistor, my main goal is to charge the capacitor at the 2200uf output in about 5-8 seconds, the input voltage is 3.7 ideally when the voltage is 6-7V for this I used two step up circuits first increased to 10V and then I need to get 80V but when I connect the second dc converter, the voltage at the output where it should be 10V drops to 3, the problem is how can I organize a cascade amplification circuit and what could be my problem? thanks for helping
Logged
Andy Chee
Super Contributor
Country:
Re: dc-dc boost convetter cascade (series)
Reply #1 on:
November 14, 2024, 07:15:32 pm »
The source pin of the MOSFET should be connected to GND.
Logged
tural_h
PGPG
Frequent Contributor
Country:
Reply #2 on:
November 14, 2024, 09:04:47 pm »
I have Motorola Databook (Linear and Interface Integrated Circuits) from 1987 and MC34063 is there. But I'm sure that several years earlier I had xero of μA78S40 (=MC34063+OpAmp). It was first DCDC IC I have read about.
20+ years ago someone specializing in DCDC told me that this IC is so old and so bad that it is waste of time to try to use it.
Just have it in mind.
Logged
tural_h
tural_h
Newbie
Country:
Reply #3 on:
November 14, 2024, 09:58:04 pm »
hello, yes you are right, it works with a frequency of 100 kHz maximum and uses a Darlington pair, which is an additional loss and slow switching, I will have to look for another option
Logged
PGPG
Country:
Reply #4 on:
November 15, 2024, 12:31:50 am »
I'm not sure, but bigger problem than these mentioned by you is its IC control scheme not ensuring even close to stable frequency.
In my opinion good ICs are those with current mode control loop (easier to stabilize than voltage mode as have one pole less in feedback loop).
I use only step-down ICs and I like the best COT (Constant On Time) control (see LM5017) as it reacts to load change in one pulse (while current mode needs 5..10 pulses to notice that load has changed).
Last Edit: November 15, 2024, 12:34:53 am by PGPG
Logged
TuralH
tural_h
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
