I'm replacing the linear power supply in a game console to save space and get rid of the large heat sink. The supply is a 7805, and I would say normal conditions draw 800mA, maybe max current draw is 1A. The input to the console is ~17VDC unregulated, coming from a wallwart. I plan on redesigning the power board, since it has a RF modulator on it that I don't plan on using in my new design.
I've never really dealt with the design of a buck converter before. I did do a lot of reading online, but I'm still a little confused.
I see there are non-synchronous and synchronous converters. What would be the best to use in my case? I've been looking in the 5V/1.5A-2A range.
The part that really throws me for a loop is the switching frequency. I see some switchers at 150kHz, but then also a lot at 1.4MHz. What would be a good all-around frequency to use?
I was looking at this part, but couldn't find much information on anyone's experience with it -
http://www.ti.com/product/TPS5405I also saw this, looks like a direct 7805 replacement, though expensive -
https://www.digikey.com/product-detail/en/murata-power-solutions-inc/OKI-78SR-5-1.5-W36-C/811-2196-5-ND/2259781Thanks in advance!
