Author Topic: DC-DC Buck Converter Questions  (Read 1091 times)
Offline Ultron81Topic starter
« on: August 30, 2019, 01:00:08 am »
I'm replacing the linear power supply in a game console to save space and get rid of the large heat sink. The supply is a 7805, and I would say normal conditions draw 800mA, maybe max current draw is 1A. The input to the console is ~17VDC unregulated, coming from a wallwart. I plan on redesigning the power board, since it has a RF modulator on it that I don't plan on using in my new design.
I've never really dealt with the design of a buck converter before. I did do a lot of reading online, but I'm still a little confused.
I see there are non-synchronous and synchronous converters. What would be the best to use in my case? I've been looking in the 5V/1.5A-2A range.
The part that really throws me for a loop is the switching frequency. I see some switchers at 150kHz, but then also a lot at 1.4MHz. What would be a good all-around frequency to use?
I was looking at this part, but couldn't find much information on anyone's experience with it - http://www.ti.com/product/TPS5405
I also saw this, looks like a direct 7805 replacement, though expensive - https://www.digikey.com/product-detail/en/murata-power-solutions-inc/OKI-78SR-5-1.5-W36-C/811-2196-5-ND/2259781
Thanks in advance!
Offline noname4me
Re: DC-DC Buck Converter Questions
« Reply #1 on: August 30, 2019, 06:54:36 am »
https://uk.farnell.com/wurth-elektronik/173010578/dc-dc-conv-buck-5v-300khz-sip/dp/2577479?st=Magi3c%205v
Even simpler?
It's a pin for pin compatible replacement for the 7805...
Sent from my SM-N960F using Tapatalk
« Reply #2 on: September 02, 2019, 08:33:59 pm »
Thanks, I'll check these out
Offline Buriedcode
« Reply #3 on: September 02, 2019, 08:45:59 pm »
Keep it simple and stupid, and cheap.
https://www.amazon.com/dp/B01MQGMOKI
I would be wary of those modules.  I have no doubt the IC does what it claims, but the IO caps tend to be grossly insufficient.  I would at least test the device with your average input and output voltage, and maximum current to see what the ripple and regulation are like.  The few of those I have tried were good up to about 600mA but lost regulation beyond it.
Online wraper
  • Country: lv
« Reply #4 on: September 02, 2019, 08:48:19 pm »
As you don't know much about them, better stay with lower frequencies. High frequency DC/DC converters are finicky and very sensitive to board layout.
Online wraper
  • Country: lv
« Reply #5 on: September 02, 2019, 08:53:41 pm »
Caps of such size should be sufficient because of 1.5 MHz switching frequency. Actual capacitance may be lower than needed though. I would suggest converter with non regulated output voltage. 3-12V range is questionable and should be sub-optimal in most of range.
Offline yashrk
  • Country: in
  • A MAKER, AN ENGINEER, A HOBBYIST FOR LIFE
    • My Personal Blog
« Reply #6 on: September 04, 2019, 06:45:24 am »
He is replacing an existing linear regulator so it must have external capacitors already available onboard which he can replace to get the requisite capacitance.
« Last Edit: September 04, 2019, 08:30:14 am by yashrk »
Find me and things I'm working on - https://www.yashkudale.com/
