"And... am i correct that it would be a bad idea if i were to connect a electronic load on the output? So i am limited to just a resistor to simulate a load."
Yes, load should be R, L type load, not an active regulator load. If you tried the latter it
could be a constant current load, but its compliance range should be limited to H Bridge
component breakdown / safe area limits. And then not a polarity changing environment.
I may be mistaken on this but electronic loads normally do not regulate a switched polarity
environment ?
Regards, Dana.
