Author Topic: Triangular wave on ring oscilator  (Read 1987 times)
Offline BelrmarTopic starter
« on: May 29, 2018, 10:58:43 am »
I recently got my first analog oscilloscope, so to start checking its integrity i built a ring oscillator, to my surprise the output from 2 of the 3  Schmitt trigger inverters are , instead of square waves , triangular, i am using only capacitors so might it be that the trigger output is getting loaded?but i am using the same capacitors so i dont know why i would have 1 of the triggers giving a propper square wave
any ideas ?
Offline Lee Leduc
Re: Triangular wave on ring oscilator
« Reply #1 on: May 29, 2018, 01:16:23 pm »
Please post a schematic. People can't help without seeing your circuit.
Thanks
« Reply #2 on: May 29, 2018, 01:32:20 pm »
on each of the outputs there is a capacitor to slow the process down
Offline Brumby
« Reply #3 on: May 29, 2018, 01:38:23 pm »
How do you think the capacitors slow the process down?
Just look at one point and think about the voltage across one of the capacitors....
« Reply #4 on: May 29, 2018, 02:00:12 pm »
well the output circuitry of each inverter will have to charge up the capacitor before it triggers the next inverter input into going low... i guess, also without them the circuit is not precisely stable, it just outputs a bunch of noise or something too high freq for my oscilloscope
Offline Brumby
« Reply #5 on: May 29, 2018, 02:06:23 pm »
You should show the actual schematic of the circuit you have wired up - not a generic image with additional wording.  A photo of the circuit would also do.  Playing 20 questions gets very old very quick - and still may not provide the information needed.
Offering answers without knowing precisely what you have wired up can cause a LOT of confusion.
The following users thanked this post: nugglix
Offline Wimberleytech
« Reply #6 on: May 29, 2018, 02:14:02 pm »
- check your connections
- check the capacitor values...all the same?
- add two more stages (5 stage ring oscillator) and see if you get similar results.
What part are you using?  Should not matter but I am curious.
What is the supply voltage?
Is the supply voltage coming from a battery or a bench supply?
Is this assembled on a protoboard or soldered?
Are you using a 10x probe on your oscilloscope?
What is the oscilloscope you are using?
Take a picture of the waveform you see and post it.
These questions may not all be critical, but the first step in getting help is to tell us EVERYTHING!!
The following users thanked this post: Belrmar
« Reply #7 on: May 29, 2018, 02:53:49 pm »
ook lets start, the oscilloscope is a promax od-416, i am using a 10x probe(oscilloscope does not have compensation for that but i can live with it) , the part number is cd40106BE, supply voltage is 12v from a linear regulator powered by a switching one.all the caps are 22nf. oscilloscope set 1uS and 2v per division (having on account the 10x)
images here: https://imgur.com/a/wEfyz6C
Offline Benta
« Reply #8 on: May 29, 2018, 02:59:13 pm »
Of course they are triangular. You have a current source (the 40106 outputs hitting their current limit) charging 22 nF. What else would they be?
The following users thanked this post: JPortici
Offline Lee Leduc
« Reply #9 on: May 29, 2018, 03:03:32 pm »
Here's an Appliation note using inverters in oscillator circuits.
https://www.fairchildsemi.com/application-notes/AN/AN-118.pdf
« Reply #10 on: May 29, 2018, 03:19:45 pm »
Great!
Your triangle waveform ramp rate is 6 volts per microsecond (deltaV/deltaT = 6e6)
I = C x deltaV/deltaT
I = 22e-9 x 6e6 = 132 mA    The 40106 cannot deliver that much current.
Therefore, I think your capacitor is not 22nF.
Please show us a picture of the capacitor markings (all three side by side).
Why are traces different???  Assuming the caps are all the same, consider this possibility.  If you removed the caps from a tape carrier (often they come this way), I have found that there is glue reside on the terminals.  This residue can insulate the wire and thus not make a connection.  Make sure the terminals of the caps are clean and making good contact.
« Last Edit: May 29, 2018, 03:26:14 pm by Wimberleytech »
« Reply #11 on: May 29, 2018, 03:29:39 pm »
agreed i made a bit of a fool of myself, the markings where 221 not 223, i should use my glasses more often
« Reply #12 on: May 29, 2018, 03:34:52 pm »
Ahaaa!!  No problem.  I wear 3x readers and sometimes even that is not enough!!
Still does not answer why one of the outputs is a square wave.
« Reply #13 on: May 29, 2018, 03:52:42 pm »
Just used another of the ic's form my batch and this one is giving me 3 square waves.... i am a bit confused, might be some esd dmg that led to a damaged output stage? a bad puppy on the batch... no idea tbh
The following users thanked this post: Wimberleytech
Offline Brumby
« Reply #14 on: May 30, 2018, 01:44:47 am »
With 3 caps on 3 stages, I would expect 3 triangular waveforms.  3 square waves doesn't make sense.  I would be really checking the contacts of those caps.
Is it still running at the same (or similar) frequency with 3 square waves?
