Hello,
I am working on a phase noise measuring system (UKW Berichte 4/2015...). It deploys an ultra low noise amplifier (10 Hz - 90 kHz, measuring range, the amp itself goes to about 500 kHz and beyond). I will use a 12 V lead battery to supply the instrument. I need +/- 8V to supply low noise opamps (e.g. LM4562), obviously of high quality (low noise, no spikes, reasonably stable). I plan to use the well known 723 for that, because of low noise. To generate the negative bias a dc-dc converter is advised, I bought a Mean Well SMU02M-12 for the negative bias. Switching freq over 100 kHz so above the highest measuring frequency of 90 kHz. That will be followed by the 723 neg reg. I have a testboard on the bench. Battery, 47 uF at the input, DC-DC converter; double PI filter at the output: 47 uF, in each + and - lead: 1 mH and 100 uF. Load is 120 ohm resistor. Scope (Tek2235) at battery: every 8usec (about 120 kHz) a big spike of about 800 mV tt. Scope at resistor is almost the same. No 723 involved yet. I am unsure whether this is pure radiation, do I need more filtering? As even the the battery terminals are polluted I am a bit unsure how to move on. I plan to place the dc-dc converter with 723 in one diecast box (12V in, -8V out).
Any advice welcome as are pointers to relevant postings or literature.
Thanks in advance,
Yrrah
