Author Topic: DC-DC  (Read 1553 times)
Offline onis_ukTopic starter
DC-DC
« on: March 22, 2017, 11:53:40 am »
If I were to power an amplifier with a laptop smps brick is there a nice way to step down the voltage from  19v dc to 12v dc?
There are plenty of crusty ebay buck converters out there but i need about 50W capacity.
Online Ian.M
Re: DC-DC
« Reply #1 on: March 22, 2017, 12:01:08 pm »
No,  50W out is 4.17A which would be really pushing it for an EBAY buck converter made of pure 'Chinesium' + there is a high probability that at light loads either it or the laptop PSU will go into discontinuous mode and produce a lot of AF ripple, and at higher outputs, the PSU and the buck converter may 'beat' with a difference frequency in the AF range.
If you need 12V at over a fraction of an Amp, for audio of any better quality than a 'Tannoy' style PA system, don't start from a laptop power brick!
« Last Edit: March 22, 2017, 12:03:30 pm by Ian.M »
Offline sleemanj
  • Professional tightwad.
Re: DC-DC
« Reply #2 on: March 22, 2017, 12:32:46 pm »
Ones like this cc buck are commonly sold as 150w at usual places, of course thatis fantasy at least without fan, but I have pulled 40w out at 10v from 48w@32v input, my notes say continuous but I don't recall how long that was for exactly, but temperature rise was 32'c
I did not look at ripple
Offline ElectronicCat
Re: DC-DC
« Reply #3 on: March 22, 2017, 01:59:03 pm »
Does it need to be powered by a laptop charger? You'd probably be better off just buying a 12v 50W power supply or re-purposing a desktop power supply. If you do need it to be powered by the laptop charger, you might be able to get away with a beefy linear regulator which would be the simplest solution, but that's assuming the laptop supply can deliver ~80W and you'd also need a heatsink capable of dissipating ~30W. Not ideal and not very efficient either. I wouldn't trust any eBay-grade buck/boost converters but you could either look into designing one yourself or buy a module from a reputable distributor.
Offline dimkasta
  • Country: gr
Re: DC-DC
« Reply #4 on: March 22, 2017, 02:42:25 pm »
Be sure to check any inrush currents on those things.
A big inrush could trigger the charger's overcurrent protection.
