Author Topic: RS232/Serial Port to Button  (Read 2288 times)
Offline gifterTopic starter
« on: September 29, 2014, 07:57:47 am »
hello guys im still a newbie and wants to learn basic electronic skills.
would like to build my own DIY serial port to button that needs to be compatible with my modem..
i have tried resources from web on how to, but sad to say im still not able to meet my goal..
Offline fcb
    • Electron Plus
Re: RS232/Serial Port to Button
« Reply #1 on: September 29, 2014, 10:03:46 am »
You'll more than likely need a microcontroller to do this, and the 'goto' solution for a newbie is likely the arduino (so start with the arduino forums).
Offline ZTE
« Reply #2 on: September 29, 2014, 08:13:35 pm »
If you're asking about creating an input from your serial port this is entirely possible, You can run a wire from the RTS pin through a switch and into the CTS pin then set the RTS pin high and when the button is pushed the CTS pin will go high, I actually use something like this in one of my projects. Just ask if this is what you're trying to do and want some more info.
