Author Topic: Microwave oven linear transformer - Primary and secondary winding  (Read 3081 times)
Offline bitluniTopic starter
    • bitluni
I have seen so many people on youtube which take the huge linear transformer and exchange the secondary winding by a thick wire to get high amps.
My question is:
Does it really matter which is the primary and secondary? Or can I just connect the secondary to mains and get lower volts on the former primary coil?
I know, I have to consider maybe the higher resistance of the thinner wire, but from my understanding it really shouldn't matter so I could use this chunky transformers
without modification to get lower voltage and high amps just by connecting it different way around.
I didn't had the luck to get my hands on one of these yet so I wasn't able to do any experiments
Offline Kremmen
Re: Microwave oven linear transformer - Primary and secondary winding
« Reply #1 on: October 18, 2013, 05:13:43 pm »
Yes, it really does matter.
Don't try it. You might live but the results won't be any good.
2nd time: it does matter. The induction in the core will be all wrong if you excite it with the secondary winding whose number of turns is so at variance with the true primary. There is more than just the turns ratio to consider, you see. There is the mag circuit that actually transfers the energy between coils and the setpoint of flux in the core should be roughly what was originally designed. Also, the microwave transformers are gapped core so their loss behavior and other parameters are far from ideal.
Do it like the others do: chisel out the secondary and wind your own. That way the mag circuit at least works the way it was supposed to.
« Last Edit: October 18, 2013, 05:37:01 pm by Kremmen »
Nothing sings like a kilovolt.
Dr W. Bishop
Online Zero999
  • 0999
« Reply #2 on: October 18, 2013, 05:26:45 pm »
You could theoretically connect the mains to the secondary to get a much lower voltage but you'll only get a tiny fraction of the design power out. The biggest problem with this is the secondary is bonded to the transformer core at one end so it's a very dangerous thing to do.
    • bitluni
« Reply #3 on: October 18, 2013, 05:51:36 pm »
This was the missing piece in the puzzle.
Thanks for the replies!
