Author Topic: dc fan control  (Read 581 times)
Offline glinjikTopic starter
dc fan control
« on: January 03, 2020, 01:10:13 pm »
hi i have tried a few of these circuits most do not work so today i got yet another circuit and tried it and it works fine very sensitive but it should not work i conected the fan to the wrong place once i realised i put the conection in the right place it then wont work? strange so i put it back to my orinal error place and all works ive highlghted where ive connected in the picture what is happening here why is it working?
All the truth in the world adds up to one big lie (Bob Dylan)
Offline mikerj
Re: dc fan control
« Reply #1 on: January 03, 2020, 01:19:51 pm »
You've just put a yellow square on the schematic, that doesn't tell us how you've connected the fan.
If you connected the fan +v to where the yellow square is, and the -ve to ground then the fan is connected directly across the power rails.  The only way the fan speed could be controlled in that case is if you have made an error in the construction and the BD140 is actually shunting the power supply and causing the voltage to drop, though this would reverse the control law
The following users thanked this post: glinjik
Re: dc fan control
« Reply #2 on: January 03, 2020, 01:26:08 pm »
hi sorry yes yellow square is where the fan + is the ground is as it is shown ive checked all connectios transistors in the right way round even the adjustment pot works fine i dont understand why its working
Re: dc fan control
« Reply #3 on: January 03, 2020, 01:31:18 pm »
after letting it run for a wile the bd140 starts getting a bit warm as expected
