Author Topic: Hard Disk power supply from Notebook Power Supply  (Read 839 times)
Offline netdiver_oneTopic starter
« on: January 02, 2020, 05:14:22 pm »
Dear All,
I would ask your advice about a little project I have in mind.
I often use a SATA/IDE to USB interface to copy data from old hard disk to new PCs. This interface comes with a black brick with 12v-5v molex connector. For three times this external power supply has failed (once blowing the hard disk it was connected to  >:(  ). I don't want to buy another one to get another piece of junk.
As I have a spare notebook power supply (19V - 4.7A output) I think it could give enough power to feed a pair of step down DC-DC converter (two of these: https://www.amazon.com/dp/B008BHAOQO)
I can connect the two in parallel to the output jack of the Notebook PSU and feed a molex female connector, stripped from and old PC PSU, setting the outputs to 12v and 5v. I think that the hard disk(s) will draw 1.5A max from both the power lines. Some hard disk have a 2.5A peak in the 12V line. I will connect only one hard disk at a time, and I would like to have a power source that would not blow up any hard disk I connect to it.
What do you think about this solution? Will it work? Would you suggest another solution? Do you think I need heat dissipation for the power regulators?
Thanks in advance.
Best regards.
Lorenzo
« Last Edit: January 02, 2020, 05:35:26 pm by netdiver_one »
Offline MyHeadHz
Re: Hard Disk power supply from Notebook Power Supply
« Reply #1 on: January 02, 2020, 05:37:01 pm »
Those little buck converters won't get near their 3a rating for any longer than a small fraction of a second, if they even manage that.  They are only good for a couple hundred ma continuous at 12v.
edit: I know because I made the same mistake a while back, in this thread.  One common solution is to hack an old desktop power supply into a "bench power supply" (at least that's what youtube calls them).  Though limited in features, they are quite robust and stable, and many people have old ones lying around.
« Last Edit: January 02, 2020, 05:52:39 pm by MyHeadHz »
The following users thanked this post: netdiver_one
Offline Wimberleytech
« Reply #2 on: January 02, 2020, 05:41:50 pm »
I have several of these and used them from time to time.  Never blew one up, nor destroyed the HD. Hmmm.  Have you opened a dead brick to see what failed?
Offline tunk
  • Country: no
« Reply #4 on: January 02, 2020, 06:10:32 pm »
First one is the original shipped with the interface... I don't remember in which way it failed...
The second one arrived DOA: since it came from China, it was very expensive to send it back from Italy, so I opened it and found out that it had a bad soldering. Repaired, after one year it made a bang and the hard disk was burned, all data lost, with a bad smell all around the room - It went directly in the bin, not passing GO.
The last one was the most expensive, but now it can't power some hard disks, so I think it is not giving enough amps. I don't want to create another unreliable PSU with my work, I only want a reliable one... but enough "portable" because I often need to make these data transfers outside my lab.
Thanks for your reply.
Lorenzo
« Reply #5 on: January 02, 2020, 06:18:24 pm »
Thanks for the "heads-up". I will read that topic in detail. For the moment I have an ATX PC PSU with a switch in the green wire to black wire connection, to power up without a motherboard connected to it, but it's not easy to carry in my backpack.
All the best.
Lorenzo
Offline niffcreature
« Reply #6 on: January 03, 2020, 11:00:24 am »
In my area it wouldn't be hard for me to find a decent 12v power supply with a few amps. Could find one at a thrift store for a few bucks, maybe even in my apartment.
But why are you using 3.5" hard drives if you need them to be portable?
Offline magic
« Reply #7 on: January 03, 2020, 11:08:55 am »
You may find external HDD power supplies from good brands at electronics recyclers, on auctions sites, etc.
Or combine separate good quality 5V/12V wall warts.
« Reply #8 on: January 03, 2020, 12:11:50 pm »
I work as a Computer Technician and I often make data transfers between old and new PCs directly at the customer's office.
BTW, I bought a new sata to USB interface that has a simple 12v wall power supply, but I would like to use also the old interface to not lose the opportunity to work with older IDE drives.
« Last Edit: January 03, 2020, 04:10:25 pm by netdiver_one »
Offline David Hess
  • DavidH
« Reply #9 on: January 03, 2020, 01:34:47 pm »
I just use a spare ATX power supply to power bare hard drives.
I agree with MyHeadHz about current derating the switching modules.  I would do so by at least 100% of the worst case surge estimate.
