Hello, My project is to convert a treadmill drive to run a wood lathe. My problem is that as soon as I connect the drive belt the over current indicator light on the circuit board lights up and the motor will run at slow speed for awhile before bogging down making a loud hummming noise. Without the drive belt it runs normal. I have had the brushed motor apart and cleaned up the commutator on my metal lathe then ran it at high speed ( belt off) for 10 minutes to seat brushes. Voltage to motor without belt is 30 to 85 volts full speed. With belt it starts at 30 will maybe reach 35 before it bogs. I have converted these drives before and one thing different about this system is the lack of choke coil. There is just a short jumper wire in its place. I'm not sure what the choke does but would like to be educated about its use. Also there is a small unit (they call it a reed switch ,pulsing 5V ) that is triggered by a magnet on the original belt drive.
In other installations I've ignored this and they have worked fine. Thanks
