Author Topic: DC SSR Won't turn off  (Read 6201 times)
Offline MatCatTopic starter
« on: August 29, 2018, 08:51:47 am »
I am using a DD220D10 DC SSR being driven by MAX4820 at 5V for control, and the supply is 72V 1400ma constant current supply, and the load is 100W LED, when all is powered reguardless of control signal (even directly grounded) the SSR will stay on.  Any ideas how to get it to work properly?
Offline Zero999
  • 0999
Re: DC SSR Won't turn off
« Reply #1 on: August 29, 2018, 09:48:30 am »
There are two possibilities:
1) LEDs can light with a very small current and solid state relays leak a considerable current, even when off.
2) The SSR has failed short circuit, which is the most common failure mode.
Test the solid state relay with an incandescent lamp. If it works, then it's #1 and the solution will be to connect a resistor across the LEDs. If it still doesn't work, then the solid state relay is bad and needs replacing.
Online wraper
  • Country: lv
« Reply #2 on: August 29, 2018, 09:55:53 am »
Part number suggests it came from ebay or aliexpress. I won't be surprised if it's not even DC SSR internally. FFS don't buy them from china, they ARE fake crap which is not safe and not nearly meeting specs. If you want it cheap, build your own from discrete components. In many cases SSR is not even needed, and simple MOSFET is more than enough.
Offline kosine
« Reply #3 on: August 29, 2018, 10:56:58 am »
Yep, at that power level you've probably cooked it. They tend to fail close circuit. Would need a big heatsink and ideally a fan for what you're doing. Something like a CPU cooler should work.
I've bought quite a few of the cheap Chinese "fotek" SSRs over the years (both DC and AC), and not actually had any bad ones yet. (Tempting fate here, aren't I...)
A couple of them have been used in factory machines and are still going strong. Maybe I just got lucky, but I must have used about 20 from different suppliers by now.
« Reply #4 on: August 29, 2018, 03:34:45 pm »
I know the relay wasn't failed before, I used the same relay to switch 50 watts with no issue (36v 1400ma), but with 100 it's no go, I will test the relay and see if it got cooked.  The LEDs seem to be coming on full tilt, not partially as if A really low current.
« Reply #5 on: August 29, 2018, 03:59:11 pm »
Any good recommendations on a NON-SSR relay?  I would love to use something in a similar form factor (screw terminals, not socketed / pinned), but that seems impossible to find.  I have 2 open auxiliary relay ports I can use to drive H Bridge for a latching relay.
« Reply #6 on: August 29, 2018, 04:08:26 pm »
The SSR form factor mimics that of the bases for plug-in relays, so you're kind of putting the cart before the horse there and also saying that you don't want a horse or a cart.  :)
Offline BergRD
« Reply #7 on: August 29, 2018, 05:23:20 pm »
Just within the last few months, a guy who added on to his Water Heater had a spectacular failure.. Beware!
I have a few of those Fotek ones to play around with but not sure I would use one of this .. 'calibre' in a critical application without LOTS of testing.
Now, yours is different but figured I would post regardless.  Good luck!
« Last Edit: August 29, 2018, 05:24:59 pm by BergRD »
Offline thm_w
  • Non-expert
« Reply #8 on: August 29, 2018, 10:13:16 pm »
youtube.com/watch?v=FV9t1GFVbhU
Big clive took a 25A unit apart and found a 8A (?) rated part inside:
So they are clearly copies or falsely labeled.
100W should be fine from a trusted seller, but I wouldn't even consider running a ~2000W heater.
edit: as said below the clearance between pri/sec is not good (8:20 in the video), so unless the real deal is a lot better, wouldn't use it either.
« Last Edit: August 29, 2018, 10:37:19 pm by thm_w »
The following users thanked this post: BergRD
Online wraper
  • Country: lv
« Reply #9 on: August 29, 2018, 10:22:32 pm »
They are also dangerous because of inferior insulation between control and power side. I would not use them even under tiny load if it's anything mains related. Actually I would not use them in any situation unless I'm on uninhabited island and have no other choice.
Offline rstofer
« Reply #10 on: August 30, 2018, 07:08:57 am »
You would be better off to just twist the load wires together.  Yank them apart if necessary.
Offline Circlotron
« Reply #11 on: August 30, 2018, 07:25:39 am »
Third possibility, the DC SSR is connected reverse polarity and it’s mosfet body diode is conducting.
« Reply #12 on: August 30, 2018, 03:05:13 pm »
They are normally constructed with back to back MOSFETs with complementary gate bias precisely to make this a non-issue. I've never seen a polarised DC solid state relay, although I'm sure that there's someone out there who's cheap enough to have made one.
