Author Topic: Dead bug copper clad prototype board advice ?  (Read 676 times)
Offline lordvader88
  • Banned!
« on: June 14, 2019, 10:33:34 pm »
I haven't used any yet, how should I clean and de-oxidize the copper before use , I have iso-alcohol and weak solder resin?
I want to make some cool RF projects soon, what's some advice for making isolation channels, or islands, I need super glue I guess. I have hot glue, is that any good ?
what tools make nice clean cuts in the copper ?
« Last Edit: June 14, 2019, 10:39:08 pm by lordvader88 »
Offline cur8xgo
Re: Dead bug copper clad prototype board advice ?
« Reply #1 on: June 14, 2019, 10:37:53 pm »
If memory serves me right you may see good examples of dead bug RF and RF PCB prototyping techniques in general in:
ARRL handbooks
Robert Pease writings
Art of Electronics
Online ogden
  • Country: lv
« Reply #2 on: June 14, 2019, 10:57:24 pm »
Wow, No!!!!   :o
You need thermally stable glue because when you solder something onto island it is heated over 250oC. Hot glue will just melt away or even vaporize.
Online bd139
« Reply #3 on: June 14, 2019, 10:58:55 pm »
I make a ton of stuff in this way.
Just clean it with an abrasive pad of some sort. I usually use a scotchbrite type thing. No chemicals are needed.
As for the islands, get some 0.8mm thick single sided FR4 PCB and some good scissors and cut it into strips. Then glue down with superglue. Do not use hot glue - it'll melt the moment you solder anything!
As for cutting the main FR4 substrate I use the following tools:
1. Scribe for marking it (copper side)
2. Metal rule for measuring (duh)
3. Engineers square for angles
4. Aviation shears for cutting it.
The latter go through the stuff like butter and makes very accurate cuts but requires some practice.
Here's a pile of stuff I made recently as an example of technique:
Try and build bits of circuits in modules, then test them, then assemble them later. Involves less pain then.
I call my technique "manflattan" as it's manhattan style but flat because I bloody hate all those excess bits of lead sticking up plus it's horrid at VHF and above.
« Last Edit: June 14, 2019, 11:00:42 pm by bd139 »
The following users thanked this post: ogden, schratterulrich
Offline wilfred
« Reply #4 on: June 15, 2019, 01:18:59 am »
What determines when a PCB might be a better option? Some of those circuits look pretty complex and not less work than etching a PCB. I'm guessing a solid ground plane factors in here somewhere.
Offline lordvader88
  • Banned!
« Reply #5 on: June 15, 2019, 03:52:54 am »
IDK what that is but it looks super cool. I've seen people use a fibre-glass brush on copper traces, I've been meaning to get 1.
I know some basic chemistry, but I don't know off hand what what works with copper. 1 thing people worry about when using acids on copper, is leaving residues that act over time. Well why don't they just clean the lot with a base ? For hobby level stuff that should be ok
Offline lordvader88
  • Banned!
« Reply #6 on: June 15, 2019, 03:55:08 am »
So 1 board is the GND plane, and I cut up a 2nd board to make conductive islands to glue down, correct ?
More reason to get a FX-888 soldering iron as well.
« Last Edit: June 15, 2019, 03:57:13 am by lordvader88 »
Offline Psi
« Reply #7 on: June 15, 2019, 04:01:51 am »
Yep, as others have said. Use a scotchbrite/pad.
Those abrasive cleaning pads you use in the kitchen to clean pots and pans.
You can also use a normal cloth with some abrasive cleaner, that stuff that feels 'gritty'.
Give the copper a really good scrubbing and then wash off and wipe with iso + clean cloth.
You will find it solders really nicely after that.
If the board is very very old and dull/oxidised you can try some 1000 grit sandpaper but this is usually not needed.
Offline lordvader88
  • Banned!
« Reply #8 on: June 15, 2019, 04:35:51 am »
Do u mean the non metal plastic type pads, often dark green colored in my part of Canada ? I think u mean nonn metal pads right ?
I do have things like 8k grit sand paper and grinding stones, but no actual polishing grit in a jar.... I have those green scotchbright pads tho, I'll try that
But for that matter, I bet if u took average sedimentary rocks that are found all over the world, that crush easy and finely, you could use that as an abrasive slurry to polish copper. Remember that after nuclear war
« Last Edit: June 15, 2019, 04:42:42 am by lordvader88 »
Offline Psi
« Reply #9 on: June 15, 2019, 04:43:06 am »
yes, the pads are green and not metal.
That said, a metal pad would probably work.  but i think the green ones are higher 'grit' equivalent so are better for pcbs.
I used to use paper towels and JIF brand cream cleaner when i did pcbs.  It achieves the same result, it's just the cleaner is the grit instead of the pad.
« Last Edit: June 15, 2019, 04:45:36 am by Psi »
Online KL27x
« Reply #10 on: June 15, 2019, 06:37:06 am »
Stainless steel wool, like you buy for pots and pans. It works great or shining up copper clad. Drop of soap, spritz of water, scrub a dub. Rinse, dry, wipe with a layer of rosin. No dust.
Online IconicPCB
« Reply #11 on: June 15, 2019, 06:47:06 am »
Simpler yet a few crystals of tartaric acid ( cream of tarter) a food sour additive from supermarket.
Wet tarnished copper, sprinkle, rub, let pickle for a few minutes rinse for tarnish free finish.
Online RoGeorge
« Reply #12 on: June 15, 2019, 07:04:29 am »
For cleaning the copper clad, I use to use toothpaste and a cloth or some paper tissue. Do not put much water, no water, or a drop or two at most, then cleanse the PCB in running water.
Alternatively, the harsh part of dish washer sponges works pretty well, too, for cleaning the oxide layer.
There is no reason to use harsh chemicals, the copper will oxidase back immediately.  The flux will remove the remaining layer anyways.  Unless you have ancient PCB, with dark brown oxide layer, you will probably not need cleaning it at all.  Usually the flux is enough.  If not sure, test it.  The solder should "wet" the copper clad.  If the solder tends to stay in bulges/droplets it needs cleaning.
Important thing while cutting the PCB:  avoid power tools that will throw fibers in the air while cutting, like a dremel tool, or at least wear a respiratory mask.  It's not smart to put fiber glass in your lungs.
Happy RF tinkering.
« Last Edit: June 15, 2019, 07:14:06 am by RoGeorge »
Offline HB9EVI
« Reply #13 on: June 15, 2019, 07:07:09 am »
Practically I'm not using any other technique than that, using a dremel bit for island cutting:
https://www.dremeleurope.com/ch/de/fraeser-hss-4-8mm-134-ocs-p
they're available in 3 different sizes
before working I'm cleaning up the pcb with steel wool
Online RoGeorge
« Reply #14 on: June 15, 2019, 07:21:53 am »
One more thing when doing RF PCBs:  leave room for shielding.
Most of the time, shielding is crucial for RF stability.
Online KL27x
« Reply #15 on: June 15, 2019, 08:38:05 am »
Yes, if you get the copper wet, it will surely oxidize a bit right after cleaning and drying it. As you say, it's not a big deal if you use the board in short order. But over time it will generally get worse and it can be a bit annoying. Even with a good flux, you will need to use MORE flux and longer dwell times.
Now that I'm thinking about it, the rosin flux coating would be a PITA for protoboard due to all the holes. I apply rosin flux to homemade PCBs by squirting a bit onto the board and then wiping it around with a bit of paper towel. It dissolves the rainbow sheen of microns-thin oxide that is already forming on the copper just seconds after drying it off. And the thin layer of rosin flux dries out in a few minutes, forming a protective layer against moisture and air. The board stays bright and shiny for months and the dried rosin flux aids with soldering. In the past I have used car wax, but I think rosin flux protects for longer
Offline StuartA
« Reply #16 on: June 15, 2019, 09:30:50 pm »
My preference for cleaning copper board is the very fine steel wool used by furniture restorers. It's much more gentle than the stuff that, say, a plumber might use. It's essential that you follow that with a really good wipe using IPA on a tissue.
For one off-jobs, I've been using stripboard a lot, but I keep thinking that I ought to re-visit dead bug again.
Offline lordvader88
  • Banned!
« Reply #17 on: June 16, 2019, 01:08:33 am »
ok I have the basics then , and I have tin snips, oh I just need superglue
Offline windsmurf
« Reply #18 on: June 16, 2019, 03:45:18 am »
... why do they call this "Dead bug"?
Offline Arjunan M R
  • Country: in
« Reply #19 on: June 16, 2019, 04:26:38 am »
I think most of them die with their legs upside down(don't know)  :D
if you put a DIP package upside down they look like dead bug.
Online Zero999
  • Hero999
« Reply #20 on: June 17, 2019, 03:15:32 pm »
An ink eraser, the gritty rubbery type, is good cleaning copper clad board.
Be careful with cyanoacrylate (super glue), it gives off nasty fumes when overheated.
Offline james_s
« Reply #21 on: June 17, 2019, 03:54:50 pm »
I don't clean it at all unless it's contaminated with something or really oxidized. The flux cleans it right up.
Offline tpowell1830
« Reply #22 on: June 17, 2019, 04:27:12 pm »
If  you're doing RF dead bug style checkout W2AEW at:
https://www.youtube.com/channel/UCiqd3GLTluk2s_IBt7p_LjA
If you use copper clad, it is called Manhattan style.
PEACE===>T
