Author Topic: Dealing with IR2108 MOSFET/IGBT Driver  (Read 3846 times)
Offline hussamaldeanTopic starter
  • Country: iq
« on: May 25, 2018, 08:56:43 am »
Hi all
recently I bought this MOSFET driver which I will use to build an inverter (single and three phase).
However, when I tried to use on of them to control the 2 mosfets I have for single phase inverter, I can see only the positive wave not the negative (i.e half-wave rectifier) based on the circuit below
capacitor 10uF 400V
resistors 100Ohm
diode 0.5V forward voltage drop
any solution or one mosfet driver drives only 1 mosfet ?
regards
Offline Seekonk
Re: Dealing with IR2108 MOSFET/IGBT Driver
« Reply #1 on: May 25, 2018, 01:10:59 pm »
I know that circuit is right off the data sheet, IT IS CRAP AND WILL NEVER WORK.  It is a test schematic for testing each output SEPARATELY.  Tie the two outputs together!
The following users thanked this post: hussamaldean
  • Country: iq
« Reply #2 on: May 25, 2018, 02:21:10 pm »
any suggestions?
Offline jdraughn
« Reply #3 on: May 25, 2018, 02:46:04 pm »
Each of those drivers will drive two mosfets, but the output on the schematic can be misleading because it looks like two outputs for connecting each side of a load when they should be tied together.  The top mosfet is responsible for passing the input voltage out, and the bottom one is responsible for passing the voltage coming in from the right, down to ground. You need two sets of the above circuit (which is a half bridge), one for each side of the load to create a full h-bridge.
Online Doctorandus_P
« Reply #4 on: May 26, 2018, 07:19:23 pm »
If you want more sensible feedback, then post the complete schematic of what you have tried, and tell us what kind of signals you have measured, and what you want etc.
A cut & paste of an incomplete picture from a datasheet does not tell us much.
  • Country: iq
« Reply #5 on: May 26, 2018, 07:24:34 pm »
Hi
I used the same circuit from data sheet and I applied PWM signal on HIN & LIN where HIN is PWM for like 10ms and pulled LOW while LIN is HIGH then HIN is LOW and LIN is PWM for 10ms
Offline Seekonk
« Reply #6 on: May 27, 2018, 06:40:18 am »
I don't understand. Did you tie HIN and LIN together?
  • Country: iq
« Reply #7 on: May 27, 2018, 06:41:29 am »
no
each one is connected to different pin of arduino
Offline Seekonk
« Reply #8 on: May 28, 2018, 12:45:08 pm »
I see no reason why you would use two pins on three phase.
Offline james_s
« Reply #9 on: May 28, 2018, 10:33:57 pm »
Keep in mind that LIN is inverted and HIN is not, so if you tie both together and drive with the same signal then the output will toggle between the two MOSFETs, which is what you want to happen.
