Author Topic: Can an Earth Ground Clamp Meter be used to measure normal AC current draw?  (Read 964 times)
Offline tigerstyleTopic starter
Question as title really  :)
Only have a Megger Earth Clamp Meter 0-35Amp capacity, can it be sued on any single phase AC circuit up to 35Amps?
I believe so but wanted to check, from a quick google it is only the resistance side of the emter that is 'special' the current side is the same as any other clamp meter?
Potential Meter at hand:
Thanks!  :D
« Last Edit: May 29, 2018, 02:18:29 am by tigerstyle »
