Author Topic: How to measure attenuation on a digital scope  (Read 1319 times)
Offline AeternamTopic starter
  • Country: lu
    • Schartz Engineering
« on: June 22, 2016, 08:54:51 am »
Hey gang,
Quick question: how do you measure the attenuation, in %, of two signals on a digital scope? See attached image: I'd like it to tell me that channel 1 is attenuated blah % in regard to channel 4.
Any ideas? (Yes I tried to RTFM but it's not all that clear, at least to me  :-DD )
Offline Rerouter
Re: How to measure attenuation on a digital scope
« Reply #1 on: June 22, 2016, 09:07:10 am »
as the 2 signals are in phase, see if it has a math function, A pk2pk - B pk2pk / Apk2pk (peak to peak)
Online Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #2 on: June 22, 2016, 12:08:45 pm »
since your reference is CH4, so CH4 is the divisor...
((2.5 - 2) / 2.5) * 100 = 20% attenuated.
  • Country: lu
« Reply #3 on: June 25, 2016, 10:53:10 am »
Of course. I should have been able to figure this out by myself. :-[ Thanks! :)
Also I found that my scope has a built in function to do this, it's called "Ratio Y".
