Author Topic: decap and bulk cap discharge path  (Read 796 times)
Offline Vcky_electroTopic starter
  • Country: in
« on: January 03, 2020, 08:21:13 am »
I have one doubt. Can anyone answer for that,
We are using decabs and bulk caps in our IC's. After power cable is unplugged, How does the capacitors are discharge?
Thanks,
Vicky.
Online mikerj
Re: decap and bulk cap discharge path
« Reply #1 on: January 03, 2020, 01:08:42 pm »
Through any components that draw power from the rails the caps are connected to.
The following users thanked this post: Vcky_electro
  • Country: in
« Reply #2 on: January 03, 2020, 02:56:05 pm »
If it is CMOS IC then how the charge in the decap discharges?
Online mikerj
« Reply #3 on: January 03, 2020, 05:40:47 pm »
What do you mean by "decap"?  If it's a decoupling capacitor across the supply rails then it makes no difference if an IC is CMOS or bipolar, anything that draws current from the supply rails will discharge the capacitors.
If you mean something else by "decap" you will have to explain or preferably give an example circuit.
