Author Topic: Svideo/Composite video no signal, timing issue?  (Read 497 times)
Offline AmmoJammoTopic starter
« on: December 30, 2019, 07:36:50 am »
I have a Denon receiver that can upscale composite and svideo to HDMI.
Connected to an old DVD/VCR combo, either input works fine.
However, I'm wanting to use this with old game consoles, Sega Megadrive, Super Nintendo, Commodore 64, etc.
So far, not a single retro console has worked.
I have known of timing issues with analog video signals before, but is this something I can measure, and "fix"?
Thanks!
Offline Benta
Re: Svideo/Composite video no signal, timing issue?
« Reply #1 on: December 30, 2019, 09:22:44 am »
The old video outputs from game consoles etc. do normally not output equalization/serration pulses during VSYNC. This might be your problem.
Offline ender4171
« Reply #2 on: January 03, 2020, 04:20:10 pm »
If it's a timing issue, you can get a Time Base Corrector (TBC), but they are quite expensive (looking at close to a grand for a good one).  Have you tried using the DVD/VCR as a middle man?  I.e. connect the console to the input of the VCR and then the output of the VCR to the receiver?  DVD and VCRs often have a rudimentary TBC built in, so that may be a useful work around.
