Author Topic: Deciphering mounted chips. Tools available?  (Read 1995 times)
Offline 240RSTopic starter
« on: October 14, 2023, 12:28:33 pm »
I have this pcb (usb phone pre amp) with an ST component that I try to understand. As so often I cannot decipher the model number from all the other packaging numbers. I guess it is a standard problems. Are there scanning apps for it?? Or lookup sites other than digikey etc? Thanks
Offline golden_labels
Re: Deciphering mounted chips. Tools available?
« Reply #1 on: October 14, 2023, 01:15:07 pm »
20% search engines, component store catalogs and datasheets. 80% experience and ability to choose promising routes and discard unlikely ones. For small SMD components (not big ICs like this) there are also various lists (example#1, example#2).
Circuits surrounding the component in question and blocks it is connected to are crucial for identification. Both by narrowing down possibilities and validating guesses.
Be aware that customized chips (often found in small, cheap devices) may not have publicly available information.
« Last Edit: October 14, 2023, 01:25:35 pm by golden_labels »
« Reply #2 on: October 15, 2023, 11:20:38 pm »
Good list. Thanks!
Anybody an idea what the numbers mean on the ST chip?
Offline alligatorblues
« Reply #3 on: October 16, 2023, 12:43:59 am »
It would help if you took a clear picture from a bit further away. My guess is it's an obsolete mcu.
Offline Shonky
« Reply #4 on: October 16, 2023, 12:45:57 am »
First step is getting a good picture. Try off angle with lots of light.
« Reply #5 on: October 16, 2023, 05:18:44 am »
Also post your guess of what it is written on the chip. You may be wrong (hence the picture is needed too), but your eyes have much better resolution and access to much richer source of information than eyes of people looking at the photo.
Tell and, preferably, show us what is around and how this chip connects to the rest of the device.
What is that device? Brand, model, exactly.
You may also look at STM32 microcontroller markings reference to get some hints. It does not contain specific part numbers, but may suggest which fragment is the part number.
« Last Edit: October 16, 2023, 05:36:05 am by golden_labels »
Offline radiolistener
  • Country: Earth
« Reply #6 on: October 16, 2023, 07:23:56 am »
This is USB sound card? What model?
Offline u666sa
  • Miami, FL
    • Codernov Electronics Repair
« Reply #7 on: October 17, 2023, 04:16:53 am »
This is the number you look for in google search
« Reply #8 on: October 17, 2023, 07:25:53 am »
I was thinking about ST33TPHF2XSPI (ST33HTPH2X32AHD4 version), but they come in QFN, not QFP cases. And what would be the role of a TPM chip in an audio amp? Not that I can’t see any, but it would still be weird.
Offline Jwillis
« Reply #9 on: October 17, 2023, 04:53:16 pm »
Could you zoom out a bit on the picture? Looks like TQFP-36 or LQFP-36. Could be a USB controller?
Offline Kim Christensen
« Reply #10 on: October 17, 2023, 05:54:14 pm »
Looks like it reads PXAHD4
« Reply #11 on: October 18, 2023, 07:38:11 am »
That helps me a lot. I have been struggling with so many ICs over the years and only now find out that there is a specific note about markings in data sheets.
I always assumed the product name would be printed. Naive…
Thanks!
  • Country: Earth
« Reply #12 on: October 18, 2023, 07:56:51 am »
any idea what is this chip?
Offline Shonky
« Reply #13 on: October 18, 2023, 10:05:50 am »
Again with the s*** pictures. Also stop cropping everything thing around it. Sometimes that helps identify it.
Looks to be some sort of arm CPU but seems strange its not square? A small Cortex M0 or similar? How many balls? X x Y?
Also the arm logo changed to lower case only around 2017 so it's fairly modern. I guess the 4419 gives that away too.
« Last Edit: October 18, 2023, 10:15:47 am by Shonky »
