First post here, and first PCB!
It's basically a breakout board for the SIM900 GSM module.
Since I'm a total beginner, I would like some feedbacks before I send it out for manufacture.
The schematics and PCB are attached below.
I've also a couple of questions:
a) For the RF antenna output, the SIM900 hardware design guide recommends using 50ohms impedance controlled traces, and an antenna matching circuit. This seems to add quite a bit of complexity, so… Is this really needed?
In my circuit I just connected directly the RF_ANT output of the SIM900 to the SMA connector, using a short (~8mm length) 25mil trace. Will it work?
b) Is the grounding good enough?
c) Tenting or not tenting the vias? In my design most are tented.
Thanks for reading
