There is this radio I have two of because I typically use it all day as long as I'm awake... I don't trust the no-name battery to be safe to charge every day, and besides one I have in the kitchen I want to leave plugged in and always there.
Anyway, typical very old phone / digital camera style Li-ion 3.7v battery, also known as "BL5C" is used
It does not have any kind of DC power input, only micro USB for charging the battery.
Even with a battery removed, if the unit is switched off, the battery charging animation appears.
I'm not sure if it's simply what is displayed in that mode, or if the charging circuit is active
I could measure some voltage at the battery charge pin, but of course i'm putting some kind of a load on it, what's more the Battery Size Indicator pin is around 82 kOhm so I was wondering if the resistance of the DMM is close enough that the charge circuit starts outputting power.
In other words, i'm not certain that the battery charge circuit is active when i'm not measuring it.
Should i cut some traces related to charging the circuit and call it a day? Could anything bad even happen if left in the "standby/charging" state for an extended period of time?
