Author Topic: Dependent voltage source circuit analysis  (Read 14988 times)
Offline MikeKTopic starter
« on: March 24, 2012, 11:50:41 pm »
I've run into a problem in the MIT 6.002x course.  We have an exercise that was given two different answers and we're not sure which is correct.  And we haven't heard from the staff yet.  So I'd like to ask the real electrical engineers a question.
I should point out that I'm not looking for the solution to the exercise (I already have it), but clarity about method.  And, in fact, please don't provide an overall solution, because there are still students who have not gotten to this exercise yet.
The question I have is...Should alpha be included in the calculation of the Thevenin resistance?  See the attached circuit diagram.  I say the resistance is R1||R2, while others say it is (R1+alpha)||R2.
« Last Edit: March 24, 2012, 11:52:46 pm by MikeK »
Offline IanB
Re: Dependent voltage source circuit analysis
« Reply #1 on: March 25, 2012, 12:56:37 am »
I'm not doing the course, and I'm not an EE, but I believe the essence of Thevenin is that a combination of linear elements must also behave linearly. Linear means "straight line", and you only need two points to define a straight line. So you find two conditions of the circuit that are easy to solve (often by forcing currents or voltages to zero), and then connect these two points. Any simple linear circuit that is equivalent for the two known conditions must by definition be equivalent for every condition.
In this case my intuition says that since alpha is a resistance that appears in at least one path between terminals, it must appear in the solution. The only way alpha could not appear in the solution is if it linearly cancels out for all possible circuit conditions. I have not tried to solve the problem, but in general for alpha to cancel out would require all the circuit parameters to be chosen as a particular special case. In the general case cancellation isn't going to happen.
« Last Edit: March 25, 2012, 12:58:23 am by IanB »
Offline Rufus
« Reply #2 on: March 25, 2012, 01:39:27 am »
The Thevenin equivalent resistance determines the short circuit current. The only solution for short circuit current requires i to be zero which makes alpha irrelevant.
Offline amspire
« Reply #3 on: March 25, 2012, 03:05:54 am »
That is true for the short circuit, but to calculate the Thevenin resistance, you have to determine the open source voltage.
I don't know if the course is pushing you towards a particular type of solution, but for one approach, define a current iR2.
You know VOUT = R2 * iR2  and the input current = i1 + iR2. Just come up with another equation that gives iR2 in terms of i1. Use this to eliminate i1 from the second equation and then you can work out iR2 as a function of the current source, and hence VOUT as a function of the current source.
Divide VOUT by the short circuit current in terms of the current source  and you have the result. Rufus has given a good clue about how to work out the short circuit current, but since you have worked out these beautiful equations, make R2 0 ohms to find out what happens when the output is shorted.
Sorry if that is not great to read, but I was trying to give a method that doesn't actually solve the problem.
Richard.
Offline IanB
« Reply #4 on: March 25, 2012, 03:21:48 am »
It's over thirty years since I was introduced to this kind of subject matter and I haven't really touched it since (electronics is not my field). So I've been racking my brains to see if I can reach back over the intervening years and figure it out from scratch.
Clearly you can solve the problem by algebra and nodal analysis, but there should be an "easier" way, a short cut to the solution.
The hint says to add another current source at the port and use superposition. Presumably by choosing an appropriate current source you can make something cancel out and leave a simpler problem? But I can't quite see what that magic current value would be?
« Reply #5 on: March 25, 2012, 03:43:36 am »
Nodal analysis does solve the circuit and give the Thevenin voltage, but it says nothing about the Thevinin resistance.  I hope Dave chimes in on this one.
Offline IanB
« Reply #6 on: March 25, 2012, 03:59:37 am »
You can work out the short circuit current, and then I believe the Thevenin resistance is the Thevenin voltage divided by the short circuit current?
But I want to think you are not intended to do a laborious nodal analysis on this circuit. There is meant to be a quick and easy way to arrive at the answer.
« Reply #7 on: March 25, 2012, 04:40:06 am »
Actually, I think you can't.  Because shorting out the terminals causes an invalid circuit (two different sources in reverse parallel).  Already tried it and got weird results.  Hopefully some EE's will comment.
Offline Rufus
« Reply #8 on: March 25, 2012, 04:48:11 am »
You don't have to calculate it to know that the calculation won't involve alpha which is enough to answer the OP's question.
Offline vk6zgo
« Reply #9 on: March 25, 2012, 04:55:45 am »
How about a "Tech's" comment? ;D
Way too long since I did anything approaching this stuff,but,as Thevenin is normally a voltage based form of analysis,I think you need to convert the current sources to voltage sources to apply it.
Do they show you how to do that?
If you can analyse the circuit that way,you can maybe work your way back to what they actually want you to do.
One suggestion is to look at other books,not just the one they specify,as sometimes the explanation of one point may be a bit weak.
Offline IanB
« Reply #10 on: March 25, 2012, 05:00:47 am »
If you short the output port it is like setting R2 to zero. So now the (alpha)i voltage source is in parallel with R1. Equating voltages between the two nodes across R1 (or summing voltages around the loop) gives i x R1 + (alpha) x i = 0 => (R1 + alpha) x i = 0 => i = 0. If i = 0 then the all the current I0 must flow through the output, so the short circuit current is I0.
« Reply #11 on: March 25, 2012, 05:30:24 am »
Yep, you beat me to it.  I went about it a different way.  I added another resistor to the output and solved and then compared the behavior to the Thevenin circuit I had with the new resistor.  The behavior was only the same when I used alpha in the Thevenin resistance.
So now my questions is...Why is alpha used in the Thevenin resistance?  I thought it was just a constant for determining the dependent source voltage.  It doesn't actually have a resistance of 8 ohms....I calculated it to be 8.9 ohms (by using it's voltage with it's current).  And that 8.9 isn't a rounding error.
Offline IanB
« Reply #12 on: March 25, 2012, 05:39:06 am »
I don't know yet. I'm still fumbling my way here. I have not actually solved that example problem in a way I can really understand, such that it becomes transparent to me. Doing nodal analysis and algebra just doesn't feel right. I'm in the process of watching Agarwal's lecture on superposition and Thevenin in the hope of gaining further insight  :)
« Reply #13 on: March 25, 2012, 06:04:07 am »
Oh, I could do algebra all day long.  Love it.  But your explanation about the short circuit current helped.  I was getting confused, not realizing what i=0 really meant.  Thanks.
I hope someone can help me understand why alpha is used in Rth, so I can be confident in the process.
Offline Rufus
« Reply #14 on: March 25, 2012, 06:09:39 am »
Oops I was wrong. Right about i=0 and alpha being irrelevant for a short circuit, wrong to infer that made it irrelevant to the Thevenin equivalent resistance.  We know the short circuit current and can calculate the open circuit voltage so we know the Thevenin resistance. I don't know how to express it algebraically.
On current controlled voltages sources - they have a conversion constant in volts per amp which is the same unit as resistance. They don't have resistance.
Offline amspire
« Reply #15 on: March 25, 2012, 06:26:15 am »
Ah! I didn't actually read the hint.
Looking at it now. it is really easy.
First you can take off R2. Get the Thevenin circuit of what is left. Open circuit volts is just Io  x R1 + Io * alpha. For resistance, take Io away and add a current source on the port. Lets call it I2.  Vout = I2 * R1 + alpha * I2, Divide by I2 both sides and you have the Thevinin impedance (Since I0 had infinite impedance). You can leave I0 in if you like, but you will just find the effects of the two sources just add together which I guess is what they meant by "superposition of sources".
Now we have the Thevenin voltage and resistance without R2. Adding R2 back is a simple solving of a voltage divider and parallel resistors.
Richard.
Offline IanB
« Reply #16 on: March 25, 2012, 06:27:12 am »
OK, I've "got" it now. I stopped trying to work it out in my head and resorted to pencil and paper.
The Thevenin voltage can be found by nodal analysis and algebra. I think there is an easier way to find it, but that hasn't been covered in the course yet.
The algebra is a bit ugly, but the result comes out as:
V(Th) = (I0)(R2)[1 - R2/(R1+R2+alpha)] = 2.13 V
Superposition comes in when considering the Thevenin equivalent resistance. We are looking for the resistance "seen" by an external current source. So we can suppress the internal current source for this calculation as it becomes irrelevant. As soon as we suppress I0, we can rearrange the circuit and it immediately becomes obvious by inspection that:
R(Th) = (R1 + alpha) || R2
This happens because when the current source is suppressed it becomes an open circuit and vanishes from consideration.
[Edit: cross-posted with Richard. Got to cross check with that and see if I missed a simplification.]
« Last Edit: March 25, 2012, 06:29:18 am by IanB »
Offline IanB
« Reply #17 on: March 25, 2012, 06:36:11 am »
I'm lost at "taking R2 away" and then "adding it back in again". Are you saying to work out the Thevenin equivalent of the simpler circuit with R2 absent, and then combine that simpler Thevenin circuit with R2 to get the new Thevenin equivalent with R2 back in? (Goes away to try working that out.)
Offline IanB
« Reply #18 on: March 25, 2012, 06:47:46 am »
Yes! Same answer  :)
Note to self, bleeding obvious department: if any whole circuit has a Thevenin equivalent, than any sub-circuit will have a Thevenin equivalent too. You don't have to do it all in one step, you can do it in smaller steps and you must by definition get the same result (otherwise the Thevenin equivalent circuit would not be as equivalent as it is supposed to be...)
Offline IanB
« Reply #19 on: March 25, 2012, 07:36:39 am »
I finished watching the lecture, and he does explain most of the points above. It's fast paced, but he covers the idea of suppressing any internal (non-dependent) voltage or current sources and looking at the resistance of the circuit as seen by a current source from outside, and also the idea of breaking a circuit into parts and working out the Thevenin equivalent of just a part of the whole before recombining.
« Reply #20 on: March 25, 2012, 02:51:14 pm »
What I don't understand is WHY is alpha used in Rth?  8 ohms is not the resistance of the dependent source.  If I calculate the voltage across and current through the dependent source, and divide, I get something other than 8 ohms for the resistance.
Offline IanB
« Reply #21 on: March 25, 2012, 03:35:14 pm »
I think you have something wrong. 8 ohms is the resistance of the dependent source (when the current through it is i -- if the current through the dependent source is not i then its effective resistance is something else of course, although resistance is not really the right term to use in such case).
« Last Edit: March 25, 2012, 03:38:40 pm by IanB »
« Reply #22 on: March 25, 2012, 03:50:21 pm »
"i" is the current through R1, not the dependent source.  The dependent source is linear (and defined as such), so it's resistance must be constant.  If you calculate it's voltage drop and current you never get 8 ohms, for ANY setting of Io.
Offline IanB
« Reply #23 on: March 25, 2012, 04:15:46 pm »
But the current "i" depends on the conditions in the rest of the circuit, so the dependent source cannot be considered to have a resistance in the conventional sense. To have a resistance it would need to be both linear and independent. Since it only satisfies one of these conditions it cannot be looked at in isolation as an independent circuit element. (This circuit is arranged to be vaguely like a transistor, where "i" might be the base current. If you considered the voltage and current relationship between the collector and emitter of a transistor you would also find it to have a non-constant resistance, since it depends on the current at the base.)
Another way of looking at this is to ask, "What is the Thevenin equivalent circuit of the dependent source alone?" As such it should have a fixed voltage in series with a fixed resistance. But since the voltage depends on i which is an external parameter, it is not possible to represent the dependent source as such. There is no Thevenin equivalent circuit for the dependent source alone.
« Last Edit: March 25, 2012, 04:19:22 pm by IanB »
« Reply #24 on: March 25, 2012, 04:28:32 pm »
Right, I understand all that.  But I'm having trouble understanding why the 8 ohms is used to calculate Rth, since 8ohms is not the resistance of the dependent source...and in my mind it's just a conversion factor.
I have no problem now getting the short circuit current and using that to get Rth, but it's maddening to see that Rth can be calculated by using alpha and not understand why.
