This is for a hobby project. A small DC motor is battery powered. The motor is geared and it produces a bit of noise at high speed. The goal is to design an enclosure for it so that the output shaft protrudes out and drives a load but the noise is largely dampened or isolated.
Any suggestions? For example, should there be a lot of air surrounding the motor inside the enclosure or it's better to fill it solid with a dampening material?
Thanks
