That's some nice hard work, it's very compact.
*compliments my work... proceeds to demolish it with devastating criticism*
Thanks so much! love that
With no negative feedback loop (from the loudspeaker back to the pre-amp) this will have much hum, noise and gain, very hard to tame. The original Marshall has push-pull with loop feedback. The EL84 would need some extra circuitry if it drives the output transformer with no NFB. I'd consider adding a radiator wire too if you like a bit of wail, something Mesa does.
Yeah, I came across a message of yours in a similar thread here from 2017 where you mention that wire, but isn't it meant to do the exact opposite? isn't the wire there to push the amp into feedback oscillation instead of taming it? At any rate, it sounds like a great idea to try, and adding negative feedback too. I will google the original schematic to find out which stage does the NF plug to.
A ground-pour does not cure all ills, and adds to problems with high voltages and high impedances. You must have proper spacings and better off with no ground fill on some traces/sections. Vox AC15 screwed that up and has arcing and carbon-tracking problems: https://www.eevblog.com/forum/repair/working-on-a-smoked-vox-ac15-guitar-amplifier
Oh, I thought the issue was just stray capacitance of tracks+gnd plane rolling off high freqs. Charring sounds a lot scarier!
Unfortunately that link is broken, but I'll look that up
The via's coming from your rectifier diodes does not have decent creepage/clearance.
Roughly, 400VDC/AC is about 1.5-2mm minimum. This is just for the HV terminal block, rectifiers, B+ feeds, and plate circuit. You can have much less spacing on signals as they are low voltage, but even a few pF of PCB stray capacitance can roll off the highs.
Oh, that's something I thought I got tackled. I thought I was good with 1mm spacing for my vias since they will be coated. My PWR netclass has 1mm spacing, but that won't be enough separation between bare pads and tracks or vias, right? bummer. I'll see what I can do about that. I wonder if there's a way to set different spacings for bare pads and coated vias/tracks in Kicad
Note your filament trace (V1, V2 pin 9) runs real close the input parts (i.e. R2) and overtop sensitive pcb traces (to C2), which is a no-no. You would have a ground guard-band around all sides of the filament trace(s) and run no sensitive signal traces crossing over top. You get capacitive coupling of hum. DC filaments for the pre-amp tubes is the quietest; the tubes with cathode bypass capacitors it doesn't matter to them. Some product designs use flying wire only for the filaments instead of the pc board.
I see what you mean. Another great piece of advice, thanks again. The first stage is good, I think, but C2 is at the input of the 2nd stage, which becomes the first in the low channel, so yeah, that's a screw up (I assumed that the signal would be large enough after the 1st stage of amplification -some 30dB- that it wouldn't matter, is that wrong?). I'm not sure there's a lot I can do about it though. No matter how I route this thing, I'm going to have some signal traces on top of the filament's, I reckon. Because it doesn't make a difference if the track that crosses the filaments is the one that goes to the grid, the cathode or the plate, right?
It's increasingly looking like I should indeed get those filament traces out of the pcb and hook them up with external wiring.
I don't see you grouping the high-current grounds together to keep circulating currents out of the pre-amp section. The two rectifier's anodes, C7, R20, C16 should be tied together as a "power ground". The approach is to have two star grounds, one for high current and another (quiet), then tie them together at one point. The JCM-800 used chassis points for this, Fender knew to do this even in the 1950's and point-point wiring.
You don't see me doing that because I had no idea about that.
So I guess my grounding scheme is all wrong. I thought I needed to keep the power supply ground plane connected to the rest right at the star point, close to the power supply. Wouldn't it do same thing you suggest if I added another keepout polygon between the output tube and the preamp section?
