Author Topic: Help needed identifying component!  (Read 1848 times)
Offline gubenenaTopic starter
  • Country: cs
« on: November 07, 2017, 06:28:31 pm »
Thank you in advance for the help !
Need to identify the burned component.
It's a water faucet, with lmv358 and PIC16F526-I/ST, and some infrared receiver/transmitter, etc...
In the faucet it self there is a solenoid valve 14w of power.
Faucet runs on a crp2 battery 6v, 1.4A.
« Last Edit: November 07, 2017, 06:31:24 pm by gubenena »
Offline grifftech
    • youtube channel
Re: Help needed identifying component!
« Reply #1 on: November 07, 2017, 08:33:51 pm »
DABZ8
Offline Gyro
« Reply #2 on: November 07, 2017, 08:37:04 pm »
DABZ8
Yes obviously, but what manufacturer / part number is that?  ::) :palm:
Edit: I've been trying to help but haven't found a match yet.
« Last Edit: November 07, 2017, 08:39:58 pm by Gyro »
Best Regards, Chris
The following users thanked this post: gubenena
  • Country: cs
« Reply #3 on: November 07, 2017, 09:36:21 pm »
DMN5L06DMK
Thank you blue and others!.
Can I please ask you blueskull for a brief explanation on how did you came up with the part number.
My wild guess would be that you are familiar with the design, or simple there are people in this business that pretty much can figure out almost any design as soon as they see it !.
If am not asking to much, which I know I do, if you are able to as sad before just shortly elaborate or I will not push my luck with the elaboration, maybe just a simple hints, so I do the rest of the work myself !...
Thank you either way !
Offline Nusa
« Reply #4 on: November 07, 2017, 10:33:42 pm »
He meant date code.
Not the only one, but this one is better than most on smd part codes: http://www.s-manuals.com/smd
Start with the first two letters. Then if you find some matches, look at the package type.
« Last Edit: November 07, 2017, 10:35:38 pm by Nusa »
The following users thanked this post: Gyro, gubenena
  • Country: cs
« Reply #5 on: November 08, 2017, 10:35:35 am »
Thank you guys !
  • Country: cs
« Reply #6 on: December 05, 2017, 02:59:20 pm »
By measuring components seems like it's not the one !
« Last Edit: December 05, 2017, 03:02:33 pm by gubenena »
  • Country: cs
« Reply #7 on: December 05, 2017, 03:11:29 pm »
Looks to me more like TPS61040...
Which rather fits with pin outs ! Though again am not really sure....
Thanks !
