Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Desolder SMD BA5984FP - Ic is glued on the board
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Desolder SMD BA5984FP - Ic is glued on the board (Read 3845 times)
herr-stromberg2010
Newbie
on:
November 05, 2011, 09:11:00 am »
I have problems to remove the BA5984FP vom a pcb. I can use a tweezer or the hot air gun, but the ic is fixed by a very hard to remove glue, mostly I removed the IC the glue destroys the pins on the boad. If this f... glue would not be there It will be easy to do.
Can you tell a newby what to do? or what to use to solve this probs.
Logged
mikeselectricstuff
Super Contributor
Country:
Re: Desolder SMD BA5984FP - Ic is glued on the board
Reply #1 on:
November 05, 2011, 10:03:31 am »
Most glues can be softened with hot air.
The way I'd do it is to unsolder the pins with braid, use a knife to ensure all pins are completely free, then heat gently for a while (lower then desolder temperature) while lifting the IC body with a knife.
Logged
Youtube channel
:Taking wierd stuff apart. Very apart.
Mike's Electric Stuff
: High voltage, vintage electronics etc.
Day Job
: Mostly LEDs
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
